05-13-2023, 07:33 PM | #1 |
I just avoided a catastrophe
I am installing a hydroboost unit on my truck and I had my front driver side wheel off to remove the hoses from gear box and while I had the wheel off I thought I might look into the rattling sound I have been hearing. It sounds like change rattling in a can when I went over bumps. I found a large washer in the bottom cup for the coil spring in the lower control arm. I have a 77 front cross member. I looked for where it came off of and this is what I found. I am not sure if it would have ever completely fallen apart but I thank God. It didn’t. It was a complete upper control arm that I bought from CPP years ago. Now I just need to find a replacement bolt and find out what they should be torqued to.
05-13-2023, 07:43 PM | #2 |
Who Changed This?
Re: I just avoided a catastrophe
Wow, that's pretty unnerving! How's the front tire wear look?
05-13-2023, 07:46 PM | #3 |
I have not even noticed any unusual wear. A while back ago I was having trouble trying to figure out why my turn radius was messed up. The mechanic was able to mess with the alignment to get it to work right but I wonder if this was the problem. I have been hearing the rattling for probably over a year so it may have been like this for quite a while.
05-13-2023, 08:56 PM | #4 |
That's scary.
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
05-13-2023, 09:48 PM | #5 |
Call me compulsive if you like (I am) but I freak out about rattles and such and will not let it go. Sometimes, like in your case, it's warranted. My worst cases were shock studs, a loose rear brake shoe...stuff that wouldn't kill me.... No joke, I once tore my whole dash apart only to later discover the cowl was chirping on the back edge of the hood. Oh, and the time I got mad and pulled off the whole door to later discover the seat adjustment mechanisim was lacking a tension spring. But let's face it, rattles and squeaks are often a sign of a problem waiting to happen, and they can be hard to locate. Glad you found that one when you did.
05-14-2023, 09:13 PM | #6 |
I searched under the truck fairly well in the past but didn’t find anything. I have had bolts fall down into the collar in the past so I just figured that was the problem again. Who knows. I might get it all put back together just to find out that that wasn’t even the noise.
05-14-2023, 09:34 PM | #7 |
I HOPE that arm wasn't hanging off the end of the shaft when it was aligned or the man was blind. I can see the shims in the pic...he HAD to have seen the arm if it wasn't in place while doing that.
I bought a front disc brake conversion from cpp several years ago and sold most of the parts at swap meets, as I considered them scrap. I will never will buy anything from them again. All chinese junk. The original nut was a tension nut with crimped head to prevent backing off. IF the threads are imperial (USA), you can get original stye replacements and not worry about them coming off again. |
05-14-2023, 09:46 PM | #8 |
Some one was Looking out for you.
Please continue with info like this. Thanks for Sharing
05-15-2023, 08:35 PM | #9 |
05-15-2023, 09:00 PM | #10 | |
05-15-2023, 09:23 PM | #11 | |
BMW & ASE Master Certified
please say you dont have a ground wire connected to the bolt on the rag joint bolt... (thats what it looks like though)
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
05-16-2023, 03:39 PM | #12 |
Who Changed This?
Doesn't go to ground, it connects the upper shaft to the lower for horn relay grounding.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 05-16-2023 at 04:44 PM. |
05-16-2023, 09:55 PM | #13 |
05-16-2023, 09:58 PM | #14 |
Who Changed This?
05-24-2023, 11:07 AM | #15 |
Same thing happened on my 65 Impala last year. Scary, for sure. I got lucky, no damage to the car, just had to get parts and re-attach the upper control arm. A previous owner had put aftermarket control arm bushings on my Impala, which I think created the problem.
05-16-2023, 07:57 AM | #16 |
Wow, that's crazy.
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
