Old 06-04-2023, 11:12 AM   #1
Gregski
Gregski's Avatar
Anybody running manual disc brakes? Pics
Hi there in order to do some troubleshooting on my 1971 GMC 1/2 ton CORRECTION (71 cab on a 69 chassis) that came with factory drum brakes at all four corners that I have since converted to disc in the front I need to install a non power disk brake master cylinder and I would love to see some pics of how that mounts. My drum/drum setup was power so it had the big vacuum booster can on it
please and thank you
Gregski is offline   Reply With Quote
Old 06-04-2023, 11:25 AM   #2
dmjlambert
dmjlambert's Avatar
Re: Anybody running manual disc brakes? Pics
1971 with drum brakes in front, I didn't know there was such a thing.
I have a 1969 C10, I put on it 1971 donor front disc brakes and spindles with new 1971-72 ball joints and steel brake tubing, and 1971 donor rear drum brakes and new 5-lug conversion rear axle shafts. I did manual brakes. The master cylinder bolts directly to the firewall.
http://www.67-72chevytrucks.com/vboard//showthread.php?p=9167631#post9167631
Old 06-04-2023, 01:04 PM   #3
Gregski
Gregski's Avatar
1,000 Super Thanks, this is exactly what I needed to see, shoot I forgot about the proportioning block I bet its a different one for drum/drum vs disc/drum
Old 06-04-2023, 12:00 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
1971 was the first year of disc brakes in all the trucks. There were many trucks with manual disc brakes from the factory.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 06-04-2023, 12:06 PM   #5
dmjlambert
dmjlambert's Avatar
Yes that is what I thought, and I didn't know front drum brakes were an option for 1971. Gregski may have had the only one. Or it may be a GMC thing.
Old 06-04-2023, 01:10 PM   #6
Gregski
Gregski's Avatar
sorry its a 71 cab on a 69 chassis, it's been a while since I wrenched on it, please check out this thread:
"Drum to Disc" conversions 67-70 pics and videos
Old 06-04-2023, 02:43 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
I do on my squarebody. Master from a '84 with manual brakes.
Aluminum master plastic reservoir
Old 06-04-2023, 03:04 PM   #8
jocko
jocko's Avatar
yes, you can bolt directly to the firewall per djmlambert's great pic (pro looking conversion!). Also note he's got 3/16" lines on the disk circuit and 1/4" lines on the drum circuit, just like the factory 71+ disk/drum set-up. A stock 71-72 combo valve would be perfect, or you can run an aftermarket adjustable prop valve - but you are correct in that the original distribution block from a 69 is not the correct valve for your soon-to-be-modified brake system. It appears you have the correct mc in your 1st post; assuming you purchased a manual brake mc (for disk/drum), it should have the deep hole in the rear piston (as opposed to the little shallow hole that accepts the short intermediate push-rod associated with a booster. Recommend check that your mc has a deep hole piston in the bore where it accepts the brake pedal pushrod. If it doesn't, i.e. just has a shallow little depression where the push-rod goes, then you may have a power brake mc (for disk/drum).
Old 06-04-2023, 03:18 PM   #9
54blackhornet
54blackhornet's Avatar
I sold my 71 gmc 1500 a few years ago. It came with non power discs up front. Master was mounted to the firewall just like in the photo above. It took me a few attempts to locate the proper NON POWER master, finally got it at Napa by going into the old paper parts books. Guy on counter was useless.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-04-2023, 03:56 PM   #10
Gregski
Gregski's Avatar
I hear that, I hate going to the parts stores on the weekends as they give the experienced Mon-Fri the weekends off and you are stuck with the new guy in the brand new NAPA shirt on
Old 06-04-2023, 03:55 PM   #11
Gregski
Gregski's Avatar
thank you so much for that detailed explanation, no where did it say if this was for manual or boosted, I was just happy to find one for disc/drum instead of drum/drum
I will check like you suggested
Old 06-04-2023, 07:34 PM   #12
Gregski
Gregski's Avatar
I was able to stick a pen cap [Science] in that hole 1 1/2" deep would that make it the deep hole?
Some Specs
BrakeBest Select Brake Master Cylinder - New - NMC11339
Warranty: Limited Lifetime Warranty
Unit of Measure: Each
UPC: # 848074025655
New Or Remanufactured: New
Dust Boot Included: No
Number Of Ports: 2
Bore Size (in): 1.130 Inch
Reservoir Included: Yes
Bore Size (mm): 28.58mm
Reservoir Type: Integral
Number Of Pistons: 1
Sensor Included: No
Number Of Mounting Holes: 2
Gasket Or Seal Included: No
Bleeder Kit Included: Yes
Pedal Rod Included: No
Brake Booster Included: No
Port 1 Thread Size (Forward) (in): 1/2-20 Inch
Port 1 Thread Type (Forward): Inverted Flare
Port 2 Thread Size (in): 9/16-18 Inch
Port 2 Thread Type: Inverted Flare
Master Cylinder Body Material: Cast Iron
Old 06-04-2023, 03:58 PM   #13
72SB
my 72 was manual disc/drum but I converted to power.
Here is a pic as it was with stock manual MC
72SB is offline   Reply With Quote
Old 06-04-2023, 04:03 PM   #14
jocko
jocko's Avatar
Gregski, LMC used to carry manual vs power 71-72 master cylinders - here's a part # ref for you - https://67-72chevytrucks.com/vboard/...81&postcount=7
Old 06-04-2023, 04:31 PM   #15
54blackhornet
Love your L6 with power steering !
71 C-20
07 Magnum RT AWD
Old 06-04-2023, 04:47 PM   #16
72SB
If its mine your talking about, yeah it is factory PS. I pulled the huge stock steering wheel and put in a smaller one as at 6'2" My leg was sideways to hit the brakes. Easy turning with the power with smaller wheel
Now power disc/drum brakes to....
Old 06-04-2023, 07:38 PM   #17
HO455
HO455's Avatar
I don't know for sure about the master cylinders for manual disc brakes in our trucks, but I do know that in Pontiacs that the manual disc master cylinders were a one year only option and they had a different bore diameter than the power brake master cylinders did.
Last time searched for one I had to have the counterman look the number up in a BOOK! There was no listing in the computer for a manual master cylinder.
I would bet the bore diameters are different for our trucks also.
RIP Bob Parks.
Old 06-04-2023, 07:56 PM   #18
dmjlambert
dmjlambert's Avatar
Yes that looks like a deep pushrod hole so it is for manual brakes. On our trucks the bore diameter is 1-1/8" for both manual and power brakes. Keith Seymore shared the engineering charts with us on what I think is the definitive thread about manual brake master cylinders for 71-72.
This is the same thread where 54blackhornet discussed his research at NAPA going into paper parts books to figure out the correct master cylinder.
http://67-72chevytrucks.com/vboard/s...30#post8909230
Old 06-04-2023, 08:18 PM   #19
jocko
jocko's Avatar
yep, 2nd the motion that you have a deep hole non-power brake mc - good news!
Old 06-04-2023, 08:57 PM   #20
Gregski
Gregski's Avatar
and a few hours and a bucket of sweat later she's on
Old 06-06-2023, 10:08 AM   #21
americanmusc1e
americanmusc1e's Avatar
Wait!? You are building an electric truck with manual brakes!?
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 06-06-2023, 10:10 AM   #22
Gregski
Gregski's Avatar
yes, lol, please watch the video
Old 06-04-2023, 08:59 PM   #23
Gregski
Gregski's Avatar
hey bro, hey bro, what kinda carburetor are you running is that one of them organic Holley Carter Rochester Quadrajet Edelbrocks?
Old 06-04-2023, 09:18 PM   #24
dmjlambert
dmjlambert's Avatar
That's funny right there! Keep that truck organic!
Old 06-05-2023, 08:57 AM   #25
HO455
HO455's Avatar
I think they're called Quadrazaps.
RIP Bob Parks.
