06-04-2023, 12:13 PM | #1 |
GEARHEAD
1971 Buick Boattail Riviera
I've been hunting for one of these for a few years. I've seen plenty for sale but most were out of my meager budget and the few that were affordable were too rough. Until this one came up. Located north of Fargo the seller bought it 12 years ago from someone in Morehead. He said it was sitting there for at least 8 years. He brought it home and never touched it. The car is almost all original and unmolested. Only the radio has been changed. He thought the motor was stuck because it didn't roll over by hand, it did when he bought it. The gas tank started leaking after he was moving it around, I can see a pinhole. Unfortunately new tanks are not reproduced yet. So I'll drop the tank and see if it's worth cleaning up.
What's really great is the lack of rodent damage. Very few mouse nests and no stink. What's bad? Well the fuel system for sure. Might need a new brake booster. Headliner is hanging loose. Front seat upholstery is cracked and split. Armrests are bad. Rust on the quarters, fender, passenger side floor, little in the trunk and I'm sure more yet to be found. It is straight though. The only dents are on the bumpers. When I got it home I put a battery in it to see what still works. Three of 4 power windows work. Wipers work. Heater fan doesn't. Most of the lights work. I put a socket on the crank bolt and it rolled over fine. Tried the starter and the bendix sticks but it will grab and crank the engine. Didn't have spark so I filed the points and then it did. A little gas down the carb and it runs! The lower radiator hose tore from my chain hitting it but the radiator was over half full when I checked it before loading. I ordered a new fuel pump and sending unit. The cranking and few seconds of run time and nothing came out of the hose at the carb. I think someone tried to get it running before and probably failed because of that. Had clean oil in it, new air/oil filters, points and condenser and I think new plugs. I have a feeling it's been off the road since 1986-7 based on a few little things. In the trunk was a bag of car parts with a receipt from 1986. In the console were coins and some stamps. The newest coin was 1986 and the stamps were issued in November 1986. The odometer reads 52,163 and in 1986, if it had been driven average miles around 10k per year, that would be about 150k miles. It had collector plates and there's no old registration cards or insurance cards to show any use. But it sat at least 20 years and possibly as many as 37. I have a few active projects now so I'm not planning much for this right now. I'd like to get it drivable. I might try cleaning the paint and rubbing some compound on it and see how much paint is left on it. That's about it for now.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
06-04-2023, 12:20 PM | #2 |
Re: 1971 Buick Boattail Riviera
Nice, I like Rivs, One of my mom's boyfriends had one and a Toronado, he was a luxury car guy!!
Take Care Troy |
06-04-2023, 05:37 PM | #3 |
My Dad had a gold Boat tail Riv. He had a late 60's Riv before that. I've always had a liking for the Riveras
NHRA Super Street 469C It only runs 10.90 at 156 mph |
06-05-2023, 10:11 AM | #4 |
What engine does it have?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-05-2023, 06:25 PM | #5 |
GEARHEAD
The standard 455.
Waiting for parts delivery and thought I would see if there was any paint left on the top side. It's basically all brown from either surface rust, paint oxidation or maybe the primer showing through. I picked one of the worst areas on the car and started buffing with some compound and under a substantial layer of oxidation, paint appeared. There was a streak through it where the paint was gone and the primer was showing, but there is still some paint. It's going to be a long slow process bringing that back but over time it'll get done.
06-05-2023, 09:04 PM | #6 |
Very cool. It's such a great body style.
Maybe leave it patina but everything new underneath? |
06-06-2023, 06:39 AM | #7 |
Cool ride. Had a 68 with a 425 Nail head. Wicked fast for a boat! 14 flat in the quarter.
06-06-2023, 11:23 AM | #8 |
Nice. A neighbor of my father in law had one a few years ago I wanted to buy. It was NFS so I forgot about it for a good while only to see it had disappeared. Hope the new owner did it justice. Always liked that body style and the 65 model.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-06-2023, 09:19 PM | #9 |
GEARHEAD
The car only came with 1 ignition key, which is as worn as I've ever seen. No trunk key. I ordered a new lock cylinder for the trunk, it even had an AC Delco one, with multiple sites saying it's an exact fit. It's not even close. Maybe LockDoc can help me out. I've been in contact with him and I'll be shipping out my cylinder to get rekeyed.
06-06-2023, 09:29 PM | #10 |
GEARHEAD
As I mentioned before, it does fire up. I tried hooking up an electric fuel pump from a gas can and I could get it running but I had to keep pumping the gas for it to stay running. The carb is clogged up for sure. Rebuild kit is on the way. I really want to have it running ok so I can try the transmission. At least some of the brakes work. I used them while moving the car into a garage stall.
Here's some more pics showing it's blemishes up close. It's a nice car but really needs a lot of work.
06-06-2023, 09:32 PM | #11 |
GEARHEAD
The dash has cracks but probably repairable unless it's super brittle. The front seat covers are beyond saving. I thought the rear my be saved but the tops where the sun hit it directly is super brittle and cracking. The stains are not coming out very much yet either. I pulled out the headliner because it was hanging and split and the insulation kept falling out. New seat covers and headliner are still available for this. So are the armrests.
06-06-2023, 11:33 PM | #12 |
Dang! That's a worthy back seat! Any girl would be proud to spend some time back there,
06-18-2023, 09:43 PM | #13 |
BlahBlahBlah
Very cool ride, love the Rivs
06-19-2023, 09:45 AM | #14 |
GEARHEAD
It's not a driver yet. Ran into a problem with the carb kit. First issue was that the kit that was sent was not what I ordered. Not even close. Looks like a kit for a 2 barrel holley. My fault for not confirming the part number after delivery. Second issue was that the kit I did order might not have worked anyway. The carb wasn't original to the car. It was a 1975 version. Which we then found out matched the engine. Someone swapped the engine for a 1975 version, confirmed by checking casting and production codes I found. Not a big deal to me if it's not numbers matching, etc. just that the later engine was more of a choked down dog than the 71 version. Less compression, less power, probably worse gas mileage.
Got the new tank installed and we cranked over the engine until gas pumped to the carb so that's all ready to go. Mike took the carb home with him and is getting the correct kit to rebuild it then we just need to figure out how to get it back to me. The other thing we did was try out my new buffer/polisher. It takes forever to get through the crust on top of this paint but wait til you see the results. Even better than I expected from my initial attempt. It's like one guy said on my FB post, it looks good once you get that coat of primer off.
06-20-2023, 03:44 PM | #15 |
That's gonna look sharp after the buff!
That '75 engine won't have the HP, but the torque should be about the same as the '71. I doubt you'll notice the difference unless you're after a time slip. Riv's are built for comfort, not quickness (but you know that).
'71 C/20 350/T350. |
06-20-2023, 05:53 PM | #16 |
GEARHEAD
Yep, I'm really hoping it just runs well enough that I don't have to consider the next swap for a while.
06-21-2023, 02:27 PM | #17 |
Wow, that paint seems to really be cleaning up well. It's a lot of work, but will be so worth it.
06-30-2023, 02:48 PM | #18 |
GEARHEAD
Got the rebuilt carb installed and she's a runner! Still needs some tuning and may have a vacuum leak. Kind of a rough idle. I set the dwell and then had a problem getting it to run but think it was just flooded. It drove around the yard no problem. Transmission felt good, brakes are a little soft but work. No loud screeches or other noises. Has good oil pressure, doesn't smoke. Runs a little warm but if it's the original thermostat they were set at 195. I ordered a new stock one at the 195f temp. I went for a drive down to the county road and it rides nice. Power steering works great. No noises or major leaks. I don't trust the tires to risk a highway run so I just ordered a set of fresh white walls for it.
It's kind of amazing. Sitting at least 20 years, maybe as long as 35. New fuel system, clean the carb, file the points and go. It even did a little burn out in the driveway, both tires digging. It had the tag on the diff to use limited slip additive so that works. Let's see of this link will work... https://www.facebook.com/1769108114/...0760669850582/
07-02-2023, 02:59 PM | #19 |
Nice score
And the progress is coming along nicely Just keepnthose update(s) coming . . .
dont want to hear excuses, i want to hear solution(s) |
07-04-2023, 12:53 PM | #20 |
GEARHEAD
It runs but not great, especially when cold. Replaced just about all the vacuum lines and used some sealer between the manifold and steel shim under the carb. Still acts like a vacuum leak somewhere. It makes a rattling sound from the driver side when cold like something in the exhaust. Did a compression test and they are all over the place which also obviously is going to effect how it runs. Needs some miles on it which I won't do until the tires are replaced. New ones should be here tomorrow.
07-12-2023, 11:48 PM | #21 |
GEARHEAD
Tires came last Thursday, got them mounted and on the car Friday. So off we go and about 1.5 miles and ran out of gas. Lol. It was not running great, it was misfiring and not much power. I pulled over to the shoulder near the end of someone's driveway along the highway. I walked to the house, noticing a gas can by a Chevy luv being worked on. Nobody home but the dog. I borrowed the gas can, put a couple gallons in the Riv and head back home.
I add another couple gallons from one of my gas cans and check the timing again. I finally get the timing somewhere close to 8 BTDC. The spec is 4 but come on, nothing is going to run good with that little advance. But I also noticed that the vacuum line to the advance canister didn't have any suction. On a lot of these old GM cars there was a temperature vacuum switch with ported vacuum. Mine was stuck shut. So I ran the vacuum line to another manifold port. I loaded the gas cans into the trunk and try again. Much better results this time. I actually made it to the gas station. It had a bit more power but was still misfiring. I filled the gas cans and returned the borrowed one fuller than when I took it. It did drive nice though. Good smooth ride, the transmission worked great, the brakes were good. Oh yeah, when I took the wheels off to get the new tires on I inspected the brakes. Everything looked good. The pads and shoes are worn fairly evenly but have a lot of miles left in them. No leaks or broken/loose bits. I already had a pertronix ignition conversion kit ordered so I didn't mess with the points anymore. I installed that on Sunday and it was a huge improvement. The misfiring is pretty much gone. I considered putting an HEI distributor in but for a buick 455 they are really expensive compared to a Chevy one. Like $300 from summit. I got a good deal on a scratch and dent pertronix kit at Amazon for $70. The Sunday drive went much better. More power, smoother running. Monday I installed the new PCV and grommet. The rattling noise from the driver side exhaust is some kinda valve thing that is actuated after it warms up. Today I replaced another vacuum line and rerouted the other vacuum lines from the temperature switch. And also found why the vent fan wasn't running. Just a bad ground. Easy fix. Next up is replacing the belts, and thermostat. Then put more miles on it.
07-14-2023, 06:35 AM | #22 |
That Riv sure is solid for where you're located...
Robert |
07-20-2023, 11:15 PM | #23 |
GEARHEAD
Put some new wipers on. Tried for days to find 18" refills with no luck. I got some rain x beam style but they are ugly, black and have a big clunky mount. I'm keeping the old chrome ones around in case I find refills.
Also replaced the thermostat with a 180f compared to the 196f original. It held in the 180-190 for a while then crept up to 210 by the end of the 20 mile drive. Not great considering it was a cool evening. I'm going to have to see if I can find a radiator shop and flush the system. It ran decent though and I had a pleasant drive. The odometer hit 52222.2 and I really don't know if it's rolled over 100k yet. Wouldn't be surprised either way.
08-20-2023, 07:28 PM | #24 |
GEARHEAD
It's been a busy month. I work on the riv occasionally. My daughter got married a couple weeks ago. Sold a couple parts cars. Worked on the cobra a little. Helped a friend swap the transmission on his square body suburban. Did that pesky job thing to keep the bills paid. Etc. Etc.
I have been trying to flush the coolant system off and on the past couple weeks. It helped quite a bit but during the last longer drive it still creeps up to 200+. Going to keep flushing it and see what happens. The cleaner doesn't cost much. Changed the oil for the first time today. When I got the car it had clean unused oil in it. I added some marvel mystery oil to it and drove with that a while. The oil came out dirty but no moisture and still very good viscosity. Put the same mix back in it. I'm going to add some additive to the gas also and see if it helps the valves. The compression test didn't improve yet and for the one very weak (45 psi) cylinder I used the endoscope and I could see pitting on the wall. Probably had some water in it at some time. The spark plug actually looks good on it. Today I wanted to see if the cruise control would work. I got a new ball stud connector for it since the original plastic one melted on the intake manifold. The dang exhaust crossover really gets hot. Didn't find a direct replacement so I used a steel one and made it work. Then found a loose vacuum connection on the cruise. Then found no vacuum at all to that system. Started tracing vacuum lines again and found that the line from the carb to the vacuum pot on the firewall wasn't connected. Replaced that line but still wasn't getting vacuum to the cruise. I bought the service manual off ebay and found the right routing and got everything connected properly. The ventilation system works now! The fan worked intermittently and I found a bad connector on the high speed relay. The controller on the dash is working now. The ac compressor works and there's still some pressure in the system but it doesn't blow cold air. Old r12 system that was never converted but I think I can get it working. I had intermittent power to the cruise unit when I push the button on the stalk. Going to try and follow the service manual troubleshooting steps and see if I can get it working.
08-28-2023, 09:46 PM | #25 |
GEARHEAD
The original AC system was intact and still had pressure in it. It's still R12 which is expensive and hard to get. But I learned that there's an alternative other than R134. Look up duracool or 12a refrigerant. There's YouTube videos and it's widely available. You can get it on Amazon. I bought a kit off ebay that had refrigerant with dye, sealer, oil, the adapter and instructions.
If you look up the SDS for 134 you'll find it's basically flammable gasses. 12a is pretty much propane and something else like butane maybe. Anyway the 12a will mix fine with R12 so you don't have to evacuate the system. Just need the adapter for a 134 connector to put on the R12 system Schrader valve. My system is a 4.5 pound fill which is bigger than most so I opted to get extra cans of 12a. I started with 23psi still in the system, just a little low after sitting 20+ years. I started with the can that had the oil in it, figuring it wouldn't hurt. Then added the sealer, then straight 12a. Added 5 cans total and the pressure came up to 32 and blows cold. Couldn't be simpler. This stuff is more efficient than 134 and a larger molecule so less prone to leaking. It cost me about $100 with shipping and I have an extra can if I need to add more. I put the new trunk seal on the other day. Had to adjust the catch to get it to latch with the new seal. Hopefully I can tighten it down over time because it sits up higher than the quarters now.
