Wiseass secured himself a BAN
Will this setup bolt up?
67 Ben ------------------ 67 Fleetside Custom C-10 SBC 350 .030 9:1 comp. Comp Cams Extreme Energy XE256H-10 Edlebrock performer intake Screw in rocker studs Oversize valves Scat 350 crank Everything balanced within one gram. Marine grade plywood bed(looks awsome) |
![]() Join Date: Feb 2001
I just installed a 1980 front end into my 70cst. This gives me 5 lug disc brakes, a variable quick steering box, plus it's easier to do PM...I have been told up to 1987 will bolt in. After 1980 GM went metric. You may have to open a couple holes but for my 1970 C10 it was a direct swap. Hopes this helps. It would be good to get other feedback. I know just enough to be dangerous.
Regards, Dewayne70cst
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
i put a x member off a 76 on my 68, had to make a couple holes bigger, parts are alot cheaper for the newer front ends.
------------------ 68 swb fleet soon to be bagged and big block powered 68 lwb fleet in primer 35 chevy truck 97 dodge on 35 boggers 3 out of 4 aint bad! Jefferson city, MO |
