Old 06-09-2023, 10:35 AM   #1
K10-Kansas
K10-Kansas's Avatar
Locating proportioning valve
Hey do you all know where I can buy a proportioning valve? I think my chassis is a 78 K10. I've got drum on the rear.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 06-09-2023, 01:50 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Locating proportioning valve
You can get those bout anywhere... you could even upgrade to a adjustable one if you wanted
Just make sure its a disc/drum version..
You'd have to replumb some lines thoug
https://www.performanceonline.com/ is where I got all my brake stuff for my truck...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-16-2023, 07:47 AM   #3
K10-Kansas
K10-Kansas's Avatar
Hey Greg does replumb mean bleed?
Old 06-09-2023, 03:12 PM   #4
rick1956
rick1956's Avatar
I bought mine from Inline Tube recently this past year. Their PR-100 model probably fits everything under the sun...
https://www.inlinetube.com/collections/brake-products
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 06-09-2023, 04:21 PM   #5
K10-Kansas
K10-Kansas's Avatar
Thanks. I went ahead and ordered that pr-100
Old 06-09-2023, 04:23 PM   #6
K10-Kansas
K10-Kansas's Avatar
Thanks guys
Old 06-09-2023, 06:12 PM   #7
K10-Kansas
K10-Kansas's Avatar
Hey Rick1956 did your proportioning valve come with the bleeder lock bolt?
Old 06-09-2023, 07:39 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
more than likely no, its seperate tool to buy. I would recommend modifying it.
http://87chevy.com/tools.htm
easy to make if you have an extra switch.... new one should come with the switch, so you can modify your old one...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-09-2023, 08:05 PM   #9
rick1956
rick1956's Avatar
No, it did not. I ended buying one. Like Clint said, you might be able to cannibalize the switch off your old unit to use as a tool.
Old 06-16-2023, 07:46 AM   #10
K10-Kansas
K10-Kansas's Avatar
Thanks. I found a metal one on amazon. It shipped and arrived in 2 days. Worked perfect.
Old 06-16-2023, 11:31 AM   #11
Just call me Sean
Just call me Sean's Avatar
No it means modify.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 06-16-2023, 12:05 PM   #12
K10-Kansas
K10-Kansas's Avatar
Originally Posted by Just call me Sean View Post
No it means modify.
Okay thanks
