Steering column help
I am needing a little help on steering column, I had twins and my truck took a back seat to that, kids are getting a little older and it’s time to get back on this panel wagon, thing is, I had the steering colum out and can’t remember what brackets to use to put it back in, do you guys have a couple of installed pictures of the brackets to use for installation? Any help would be appreciated!
![]() ![]() ![]() Join Date: Jan 2018
Re: Steering column help
Hopefully this link will help you out: https://lugnutz65chevystepside.weebl...n-rebuild.html
It's for a 63, but is probably somewhat applicable for whatever year your truck is.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
I can’t seem to find the old column anywhere. I have an aftermarket column to put in it, but don’t have the installation brackets as I think they were with the old column. So if I could see it installed, I’d know what to order, it’s a 1960 panel wagon with a 1980 front clip installed. Also I’m putting in an aftermarket sector with u joints instead of rag joint.
Try this link. A lot of good info in it & the additional links.
http://67-72chevytrucks.com/vboard/s...d.php?t=523901 |
i have most of the brackets. im in iowa
1965 C10 long box laid out on bags ![]() instgram 65see_x .……………………….. ____ ..………________//__l \_____ ,,,,,,,/__(O)___//___/__(O)_/ |
