06-30-2023, 02:04 AM | #1 |
Correct me if I'm wrong
Cruising the depths of marketplace for a local small block for a rebuild and I saw this. Ad says it's a 350 from an 80s pickup and I wondered why there was only 1 accessory hole in the heads. Then I saw the backside and I'm guessing they swapped sides with the heads for whatever reason or is there a breed of cylinder heads that are supposed to be like this? It's been a while since I rebuilt an engine
06-30-2023, 08:45 AM | #2 |
Re: Correct me if I'm wrong
I believe that came from a 86-87 truck or van. 1pc rear main seal, 193 heads and 210hp.
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
06-30-2023, 09:25 AM | #3 |
That is an 86 to 92 350. You will need to use an electric fuel pump. During casting they blocked off the fuel pump hole. I know the BB of that time did not. I have an 87 engine and this is how I know. Also the center bolt valve covers.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-30-2023, 10:08 AM | #4 | |
I say its 86-87 because it doesn't have the lifter valley bosses cast into it.
06-30-2023, 10:48 AM | #5 |
x2.
07-06-2023, 11:09 AM | #6 |
As far as I know there has NEVER been unique left or right cylinder heads for any SBC. They all fit either left or right. On a used engine it's always possible one of the heads has been swapped for a different casting number or model year.
