Gas tank relocation
Was ordering a bunch of stuff to redo the floor, carpet and seatbelts in my 66 c10 and I want to relocate the gas tank and I have a question. I know one way this was done was to use a blazer tank which requires some modifications to be made to the bed crossmembers but do the kits offered by a variety of sites also require the same crossmember mods? I was thinking of getting my tank from Brothers/Holley and their site says very little on the subject and I don't see why a product specifically made for this would require cutting and welding.
Re: Gas tank relocation
You can mount the tanks without cutting, but of course it's going to hang down lower. The other thing is when I did mine I had to use nutzerts for the bed boards above the tank because there's absolutely no way to get a nut started for those 4-5 strip bolts unless you put the bed boards in before the tank.
#3 | |
I used the basically same one as Bobby B
John 3:16 - Saved me... God Bless |
![]() Join Date: Jan 2015
I used the LMC kit. It worked out well.
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
I used one from a Jeep CJ5 and a fill spout in the box that came off a Dodge truck. Maybe it's a little small at 14 gallons. I had to use a different fuel gauge.
66 fleetside 350 4sp |
This is what I did using the LMC truck fuel tank
That's incredibly cool and I'm wondering if your truck is a 64 that probably didn't have original reverse lights. My 66 has them and I think state inspection laws would frown upon this mod BUT I am going to inquire about it. I really don't want to cut a hole in an otherwise pristine bed but lack of options will likely say otherwise
#9 | |
#10 | |
![]() Join Date: Mar 2011
I used a 64 mustang tank. I did open the top of the frame rail about a half an inch on each side to fir the tank up a little higher and reversed the rear crossmember. It tucks up in very nicely.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
Here's a thread I started before doing mine. Granted I was more concerned with the exterior view rather than the filler location, but I figured out a semi discreet option for it too. https://www.67-72chevytrucks.com/vbo...d.php?t=621177
I kept the reverse light on the right side.
![]() Join Date: Nov 2013
Anybody have direct experience with one of the tanks?
https://www.tanksinc.com/index.cfm/p...rod/prd822.htm |
#15 | |
#16 |
I used Tanksinc's USPT universal tank. It has two options for filler placement.
https://www.tanksinc.com/index.cfm/p...rod/prd121.htm |
#17 | |
#18 |
![]() Join Date: Sep 2020
Edited by moderators.
Please remember that all parts offered for sale must be posted in the parts board section with a price. https://67-72chevytrucks.com/vboard/...t.php?f=76&a=8 Thank you Last edited by cwcarpenter98; 08-13-2023 at 09:15 PM. Reason: Part for sale with no price |
