![]() Join Date: Nov 2022
73 electric gauge in 71 dash cluster
Edit: It's actually a 78-79 electric oil gauge in a 1971 K10. I think I have the wiring correct now but perhaps the ADO-D8034 sending unit is the wrong sending unit.
Hi. I've put an electric gauge in my 67-72 dash cluster. I assume 1 post in negative, one is positive, and the other is for the sending unit. I thought about trying random setups but felt I should get advice first.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 08-01-2023 at 06:21 AM. |
Moderator
![]() Join Date: Oct 2008
Re: 73 electric gauge in 71 dash cluster
Temp gauge I presume.
Look up the 1973 wiring diagrams. The cluster layout is on the first page of diagrams.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Sorry, it's the oil gauge. Thanks for the link. It looks like based on the manual, the ground is in the middle.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
I found this picture in another thread. Someone trying to work out the same question.
Here's my current setup. The brown is ground. Pink is 12v. I don't see colors very well so I'm guessing that's pink. My blue is the sending unit wire. The oil is showing running high. I bet that's not accurate. If I flip the 12v and sending wire it sends the needle all the way to high past 60.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 07-31-2023 at 08:29 PM. |
I'm using an ACDelco Oil Pressure Sending Unit that I realized today doesn't list 78-79 c10 as a fit. It does list 1977 https://www.summitracing.com/parts/A...4/applications
I am using a gauge for 78-79 c10 https://www.lmctruck.com/1973-91-che...pressure-gauge Is it reading high because I bought the wrong sending unit? This one shows a 78-79 c10 as a fit https://www.summitracing.com/parts/s.../c10/year/1978 So maybe the make and model of the vehicle doesn't matter in relation to the engine dictating what sending unit to use but instead, the make and model of the vehicle dictating what sending unit to use per the gauge that was in that make and model?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 07-31-2023 at 09:03 PM. |
That oil pressure is a near match for what my 75 with a stock 350 shows when at speed. OEM mechanical gauge. Disclaimers - sample size of 1 and ~48 year old gauge.
My value was at idle 3 minutes after starting it. So it might be accurate?
Mine is the same cold. Once hot, the at idle pressure is lower but goes back to that when I rev it a bit. The motor has about 110k miles on it.
