Old 08-05-2023, 10:52 PM   #1
RonWT
Active Member
RonWT's Avatar
Hei or points??
Folks, I am wondeing how many of you are still running the old points style ignition or if you have converted to HEI? if you converted, what style of HEI have you went to?
Thanks,
RonWT
RonWT is offline   Reply With Quote
Old 08-06-2023, 01:24 AM   #2
CastIron
CastIron's Avatar
Re: Hei or points??
After watching the timing bounce all over at idle, I decided to replace my original distributor with a MSD street fire HEI distributor. It runs much better, but that might also be because I replaced a tired 307 with a crate 350 at the same time.
CastIron is offline   Reply With Quote
Old 08-06-2023, 02:35 PM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Hei or points??
You're a pretty hardcore "Belt and suspenders" guy ;-)
Rust_never_sleeps is offline   Reply With Quote
Old 08-06-2023, 02:46 AM   #4
Wikid61
Wikid61's Avatar
Re: Hei or points??
HEI that is tight may step up the spark a lot. Especially using quality cap/rotor/wires/ect. Another option is this: https://pertronixbrands.com/ I've ran them & the stock cap tales up less space.
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 08-06-2023, 04:25 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Hei or points??
I found a definite performance improvement when converting to HEI. I've done it on V8s as well as my L6.
I ran PerTronix for about 7 years, but it burned out on me.
GM Delco-Remy style HEI is the best, and parts are universally available in the US.
Old 08-06-2023, 08:03 AM   #6
don t. - 72gmc
Re: Hei or points??
I converted to a Skip White HEI dizzy years ago. The original dizzy, bad bushings made it wobble. At that time, $'s were tight, wanted something quick and easy.
Getting the truck back on the road this summer, wanted to R&R the cap and rotor. Skip White does not sell parts, but would sell me a new dizzy. Local auto parts guy I trust thinks he may have found an Excel cap & rotor. Parts arrive on Tuesday.
Good luck...Don
don t. - 72gmc is offline   Reply With Quote
Old 08-06-2023, 10:14 AM   #7
truckster
truckster's Avatar
Re: Hei or points??
I had a factory HEI for years. I decided to upgrade to a Progression Ignition distributor a few months ago and I couldn't be happier. It connects to your phone via Bluetooth and allows you to custom program timing maps on the fly. It also has a lockout function that will keep your vehicle from starting if you lock it on the app.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-06-2023, 11:54 AM   #8
yuccales
yuccales's Avatar
Re: Hei or points??
Member of the "Points Forever" club here. Both my old dogs still run em. I just can't part with the old Penske.
yuccales is offline   Reply With Quote
Old 08-06-2023, 12:10 PM   #9
Getter-Done
Getter-Done's Avatar
Re: Hei or points??
I still have the Penske my Daddy used and that I was trained on.
84 Chevy K-20
Old 08-07-2023, 12:55 AM   #10
Rust_never_sleeps
Re: Hei or points??
Does that thing do other tricks besides dwell?
Old 08-07-2023, 07:31 AM   #11
yuccales
yuccales's Avatar
Re: Hei or points??
Volts, ohms, rpm. For my early years that was my only "real" tester. Nowadays it just is my dwell meter.
Old 08-07-2023, 09:03 AM   #12
custom10nut
custom10nut's Avatar
Re: Hei or points??
I’ll chime in on this.
I wanted a HEI distributor, but wanted to keep the factory look.
I switched out my Dual Points for a Mallory Electronic Conversion kit.
It worked well for many years, but the module did go bad once, so I put in a new one and haven’t had any issues.
custom10nut is offline   Reply With Quote
Old 08-07-2023, 01:20 PM   #13
LNP
Re: Hei or points??
I run a HEI I got a new distributor from Summit. It was affordable came with a new cap & rotor. They even sell the wiring pigtail plug for a few bucks so you can make it a plug & play distribuotr.
https://www.summitracing.com/parts/s...ckup/year/1969
https://www.summitracing.com/parts/sum-890148/overview
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 08-11-2023, 12:52 AM   #14
howzzzit
howzzzit's Avatar
Re: Hei or points??
How about this question? How many of you running points have ever had them suddenly drop dead? How many have had a hei drop dead?
howzzzit is offline   Reply With Quote
Old 08-06-2023, 12:00 PM   #15
697498chevy
Re: Hei or points??
My '69 C 10 also has O.E. distributor . Seems to run fine . Thanks
697498chevy is offline   Reply With Quote
Old 08-06-2023, 01:35 PM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hei or points??
I converted to a used late-Seventies GM HEI back in the early 1980s and couldn't be happier with it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-06-2023, 02:22 PM   #17
Re: Hei or points??
That's what i have on my 70. I think only issue in last 25 years was 2 module died. Super dependable.
Old 08-06-2023, 02:12 PM   #18
Wrenchbender Ret
Re: Hei or points??
I have kept the points & cond. because I want to keep everything original on my low mileage 72 Super. I have a GM HEI unit that I have o-hauled that I could put on it but it runs & starts perfectly.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-06-2023, 02:33 PM   #19
Rust_never_sleeps
Re: Hei or points??
Still running points. When the original dizzy wears out, I'll think about HEI
Old 08-06-2023, 02:36 PM   #20
dmjlambert
dmjlambert's Avatar
Re: Hei or points??
I have a used 1976 to 1980 GM HEI in mine and I like it.
Old 08-06-2023, 04:18 PM   #21
54blackhornet
54blackhornet's Avatar
Re: Hei or points??
Not being able to find an original GM HEI I bought a clone off eBay from a firm named BraveX. Billet aluminum housing and good quality oil impregnated drive gear. Cap looks good too. BUT everything electrical is very low quality. The first one lasted about a year before the module died. BraveX replaced it with no questions. Second one lasted about two months. BraveX again replaced it. Third one is in and running great. Let’s see how it goes ? Another problem I have determined is you can’t buy anything under the cap that’s made in the USA any longer.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-06-2023, 04:50 PM   #22
72c20customcamper
72c20customcamper's Avatar
Re: Hei or points??
Two with factory GM HEI and two still with points they all run well
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-07-2023, 11:29 AM   #23
67C10Step
67C10Step's Avatar
Re: Hei or points??
I switched my truck to HEI and found this last statement to be painfully true. About 18-24 months and 1500 miles I got the dreaded no spark issue. Yep, module is out. So, I purchased two. One to replace and the other in the tool bag under the seat.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-06-2023, 03:25 PM   #24
body bolt
Re: Hei or points??
I added HEI 25 years ago and haven't touched the distributor since.
body bolt is offline   Reply With Quote
Old 08-08-2023, 01:03 PM   #25
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Hei or points??
X2...............I installed a Delco HEI, pulled it out of a 1975ish.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
