08-06-2023, 04:55 PM | #1 |
70+ ( Old Skool Club )
How tough to get this off ?
So want to change the bulbs in my HVAC control to LEDs and can't get my fat fingers, and neither can a buddy, to get at the tiny bulb holder out to pull it out. So thought I could remove the 2 holding screws and push it back so it hangs to get better access to the holders. Tryng to push it back the knob on the bottom slide wont go far enough back, hits AC hose, so figure the knob has to come of the slide or does it ? I gave it a tug but it didnt wanna budge and don't want to break it so do I just need more force to pull it off and wil it goack on tight if I have to use more force to get it off. ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-06-2023, 05:04 PM | #2 |
Mr. Cheyenne
Re: How tough to get this off ?
I can't answer your questions, as I switched those two bulbs to LED when I was replacing the radio and all of the hoses. I also had the glove box out at the time, which is a must if you are messing with the radio/hoses. Getting the two bulbs replaced was still a pain with all that out of the way.
Anyways, once you get them replaced with LEDs - it is a worthwhile change or at least for me it was. If I ever have to get into that area again, it will be to soon. With AC, as you know, it tight in there!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
08-06-2023, 05:38 PM | #3 |
I don't recommend taking the knob off the slider. The whole unit will come out by sliding it back and tilting it just right, and moving any offending hoses. Those bulb holders are indeed difficult to work with, even with the unit completely removed from the dash and in your hands. Another option may be to remove your seat or seats, and enjoy the spacious cab to lay on your back and work on the stuff up under the dash. At a certain point you have to figure LED bulbs don't gain you anything worth going through that much trouble. I recommend arrive at that point quickly and save changing of those bulbs for when they actually burn out. I put in all LED bulbs, and then took them back out and put in regular bulbs. The LED bulbs just weren't worth it, but that's just my opinion.
08-06-2023, 05:50 PM | #4 | |
08-06-2023, 06:04 PM | #5 |
Well I would say get a teenager to do it, but they might damage something. So it will take patience and gentle work and a little bit of bodily and facial contortion.
08-06-2023, 06:20 PM | #6 |
I just took some pictures of one I have.
Here is 1 picture and 5 more on the way.
08-06-2023, 06:26 PM | #7 |
If you need more Pictures I can send them
08-06-2023, 07:02 PM | #8 | |
08-06-2023, 06:47 PM | #9 |
Why are you showing those tabs? I don't think they are related to doing anything with the bulbs. I may be missing the point, sorry if that is the case.
08-06-2023, 06:48 PM | #10 |
Can you show a picture of the back of the controller, where the bulb holders are?
08-06-2023, 08:00 PM | #11 |
I got confused about who was helping who. So the pictures are not from the problem truck, they are just for helping get an idea of what's going on.
08-06-2023, 09:45 PM | #12 |
One of the bulbs is beside the switch.
08-06-2023, 09:52 PM | #13 |
The drivers side bulb is beside the switch
08-07-2023, 06:18 AM | #14 |
08-07-2023, 02:57 PM | #15 | |
08-07-2023, 06:17 PM | #16 |
Those round holes are where the bulb holder pushes in. Pull or pry the bulb holder out of that round hole to gain access to changing the bulb. On mine if I can recall correctly, the bulb holder has a bayonet bulb socket for an 1895 bulb, and the perimeter of the bulb holder has many (or several) fingers that hold the assembly in the round hole of the controller, and those many fingers provide the ground for the bulb. I don't have the original bulb holders for mine, I bought new generic ones, so I'm not 100% sure on how the originals would have worked.
08-07-2023, 08:05 PM | #17 |
another option, remove the glovebox innards which will allow you to get your fatty fingers back there a bit easier. this really is an any replacement with "normalish" fingers and recommend just finding someone with small fingers. good luck
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
