Finally done the hydroboost lines!
Took a very long time to come up with a way to run these lines to include a cooler, and keep it neat. No inner fenders yet, as they are being color matched to the truck.
"If it ain't broken, fix it 'till it is!" |
#2 | |
The Older Generation
Re: Finally done the hydroboost lines!
Looks really nice. Just the opposite of mine.... ![]() I hope you have enough power.... j/k LockDoc
![]() Join Date: Jul 2000
That looks like a 600-700 lb ft torque monster! What kind of trans and rear end?
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#4 | |
Wanted to put a 4L75-R behind it, but money is running out. Just gotta take it easy...get it drivable again first.
That's just insane (in a good way)! Why a locker instead of a regular posi? Does it chirp the tires during turns?
Just the opposite. No clicks, clunks, or bangs, when turning corners. Just smooth lockup whenever you smash the go pedal.
![]() Join Date: Sep 2014
I request a video please!
Gotta get it all back together first.
Started the engine swap last fall, and just kept getting deeper, and deeper, with changes. Hopefully by next spring it’s done. I’d be happy just hearing the engine run...but it needs everything from the collectors back... Plus all new brake lines for the narrowed rear... Finish the Vintage Air install. Bolt the custom transmission crossmember into place. Finish the rewire job under the hood. Speaking of hood...needs a hood with a 3” cowl of some sort. Doors are open, as the Mustang mirrors are being color matched. Single glass window install to do. (Because of the Mustang mirrors) That’s just off the cuff...
#9 | |
Auuuugh...no.
It ran too smooth with the old big block. No lumpity bump at all. I can’t leave anything stock, and never happy until I go too far...then I drop back to the last functioning combination.
The True Track uses gearing internal to slip when needed and lock up as needed. I've used them on a number of hot rods and they worked well. They don't need posi additive since they don't use clutches.
