![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
Exhaust manifolds glowing red.
First start up after rebuild.
2,000 RPM break-in and noticed they were glowing. So I shut it off. I think the carburetor needs to be tuned because I can't get the RPM past 2,000 when WOT. Just glad I was doing this in the evening outside my garage. I was able to notice the glow. |
Who Changed This?
Re: Exhaust manifolds glowing red.
Lean mixture. In general, high idle speeds will give a lean mixture unless the choke is closed slightly during break-in. Closing the choke a little will cause the speed to increase. You just need to use something to hold it slightly closed at an optimum idle speed, since the automatic choke will be hot.
Timing too retarded will cause the same thing.. Spark fires late and the burn process hasn't completed when the exhaust valves open.
Vacuum leak too. Inspect above notes, and correct.
So I finished the cam break-in. All went well. The timing was off so now that's been adjusted. Except the rear main seal is dripping oil like crazy. So I drove the truck to the shop that rebuilt the motor. The shop is gonna keep the truck over the weekend to repair the oil leak. Once that's done, gonna flush the water and refill with coolant, slap the new cowl hood on, and enjoy.
![]() Join Date: May 2004
so it was just the timing being off? Was it a significant amount?
Not sure if bad timing had anything to do with the glowing manifolds. Not sure what's a significant amount for the timing, but it was hard to start, idle was rough, the idle was almost like a drag car, very little power. Adjusted the distributor and the carburetor multiple times. Checked timing with a strobe. Got it to idle around 700. Now she purrs like a cat.
cool...thx for the update
![]() Join Date: Jun 2022
![]() Join Date: Nov 2019
A carb meters the fuel by "sensing/reading" the incoming flow of air. If there is air be introduced into the intake after the carb it will cause a lean condition because it is getting more air than the carb is calibrating for.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
yep, just wasn't sure if there was some other effect
Gotcha' - Sorry, I didn't mean to be condescending
![]() Join Date: Jul 2000
Was just one part of one manifold glowing red? That could mean a problem only with that cylinder. Have to wonder what the spark plug, valve, and top of piston look like.
Let us know when you find the culprit.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
