09-12-2023, 08:33 PM | #1 |
Gas Tank cover required?
When installing a “Carpet Gas Tank Cover”, is the Fiberboard GasTank Cover required?
Does it give a smoother base for the carpet to lay on? I’m about to order my new carpet and plan to also get the carpet cover for my gas tank. My original cardboard cover finally “gave up the ghost”, so I’ll have to order a new on, IF it’s needed. If not, I won’t bother. |
09-12-2023, 09:30 PM | #2 |
Re: Gas Tank cover required?
Bucket seat trucks did not also have the cardboard cover. The carpet covers have a jute backing.
Jim Last edited by FirstOwner69; 09-12-2023 at 09:38 PM. |
09-12-2023, 09:34 PM | #3 |
09-12-2023, 09:45 PM | #4 |
Correct. I added a note regarding a jute padding added to the the carpet. Apparently we both hit "enter" at the same time.
Jim Last edited by FirstOwner69; 09-12-2023 at 09:54 PM. |
09-12-2023, 10:03 PM | #5 |
Check out this thread.
https://67-72chevytrucks.com/vboard/...d.php?t=268050
Jim |
09-12-2023, 11:35 PM | #6 |
My 67 didn't have any cardboard. The rug was glued to the tank at the bottom from factory with some black type glue. I will not glue it when I'm finished with the interior. Also mine had no jute on of from the factory.
09-12-2023, 11:50 PM | #7 |
I wonder what all the variances were factory. I found my 71 fremont built Deluxe and bench seat with the fiber board, and I'm pretty sure it's flaps fit where it needed to without needing clips.
Found my 72 fremont built Super and bench seat with just insulation glued onto the tank, and perhaps to the floor underneath the tank. Though that may not have been factory. I installed this, post 50 into my 71. Nice cover, thoughtful provisions and easy to install. It's pending seat belts and flooring yet. http://67-72chevytrucks.com/vboard/s...=846616&page=2
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-13-2023, 08:39 PM | #8 |
Thanks for all the reply’s and input.
I think I’m gonna use a Fiberboard cover under my carpet, aiming at giving it a smoother appearance. They’re less than $30 so if I don’t like it later, I can always take it out. |
09-13-2023, 10:15 PM | #9 |
I didnt put the cardboard in when I did my bucket swap, the ACC cover lays pretty darn smooth once you get it installed. I had to trim it at the bottom where it meets the floor.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
09-14-2023, 01:11 AM | #10 | |
My top RH side leaves some to be desired but that corner has the vapor assembly, and that's more than a few lines. To a lessor degree, the lower corner is effected as well, Does your tank have the vent assembly? Ooops, that's a 1968. Is yours the molded cover or what they call their loop? Mine is the loop, with jute.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-14-2023 at 01:34 AM. |
09-14-2023, 09:21 PM | #11 | |
09-14-2023, 11:02 PM | #12 | |
09-28-2023, 01:35 AM | #13 |
Bumped for samkost
09-28-2023, 11:12 AM | #14 |
Perfect timing!
Just what I wanted to hear to proceed with my tank cover and mass backed carpet. I was concerned with the excess on the bottom, how it was fitted to blend with the carpet and then to cut for the seat belt hardware. In my case measure twice cut once. Thanks Tony and CAMAROBOY68SS. Big help!
Sam 1972 C10 LWB 2020 Z71 Tahoe |
10-01-2023, 02:46 PM | #15 |
Well its installed
As others had said, I had to trim the bottom of the tank cover to tuck it under the finished edged ACC carpet. The excess I used to finish and cover the small gaps at the door jambs. This was an older non molded cover that I purchased several years ago. It fit and laid down pretty well for the style. Overall I’m very happy with the outcome and it will finish off nicely behind the bench seat. The carpet fit was right on with only some slight trimming required at the thresholds.
