09-13-2023, 11:36 PM | #1 |
Budnik wheel backspace
Wondering if anyone can shed some light on what they have run on their wheels backspacing, front and back. Ideally, I would like to have some sort of turn radius when aired out or a couple inches higher than completely aired out, if possible. I plan on having a bump step welding up to stop be a few inches from completely bottomed out. The back I’m just looking for the wheels to tuck as high as they can. Was looking at 20x8.5 and 20x10 budnik spyders. Tires, I was looking at 235/40/20 and 285/35/20. Thanks in advance
1986 c10 pickup Front: Factory control arms Vannatta front inner fenders Bags with plates and cups Rear: Stock bed floor, tubs and rear end width Ridetech bolt in 4link with the shockwaves |
09-18-2023, 06:02 PM | #2 |
Re: Budnik wheel backspace
5-5.25" BS fronts
5" BS rears (stock axle width) First 2 pics are 20" Coys (8.5"F w/5.25"BS; 10"R w/5.5"BS). Third pic is AR TT2's (18x8"F w/5.25"BS; 20x10"R w/5.0BS).
09-20-2023, 01:32 PM | #3 |
Thank you for the reply. Exactly what I was looking for…couple questions. One of budniks install referrals is saying he remembers possibly 4.25 and to be safe 4.5bs, not sure if that’s the front or back, did not specify in our convo. The 20x10 looks like it’s exactly what I need. This truck on air ride or static?
09-20-2023, 04:45 PM | #4 | |
If you're planning air ride & using OE length arms up front, you'll want more BS to tuck the wheels in from the fender lips. Narrowed a-arms & less BS works toward that goal as well.
09-20-2023, 11:05 PM | #5 |
So a 4.25 or 4.5bs up front is a no go for sure. I think I have read on here somewhere that 5.25bs up front on a 8/8.5 wheel is what some guys prefer.
09-21-2023, 09:02 AM | #6 |
Those numbers would work but you'll rub the fender lip sooner vs. w/more back-spacing. Not an issue w/a mild drop but can be w/aggressive drops.
