09-24-2023, 01:56 PM | #1 |
67 suspension height/drop question
Hey everyone. I posted in another thread about completely rebuilding my front end.
Well, I’m deep in this thing and discovering little things along the way. Upon tearing everything apart, it seems the last owner was using or installed McGaughy 2.5 drop spindles and what looks like cut OEM front coils. For me, the truck as it sat was way too low. I really like the 2.5/4” stance I see on this board as the truck is a bit more useful driving around for me. However…this truck has been C notched in the rear, and it looks like a 6” drop. So basically it originally looked like a 4/6” drop. I’ve also decided to go with CPP tubular control arms, upper and lower. So… should I simply go with OEM height springs all around? OEM height just on the front? What brand is good? Moog? POL? CPP? What will I need to do on the back? Thanks! Last edited by SilverGT3RS; 09-24-2023 at 02:22 PM. |
09-24-2023, 02:15 PM | #2 |
Re: 67 suspension height/drop question
Original coils on front and 4" drop springs in back assuming you have a coil spring trailing arm rear suspension.
The good thing is you can tune the rear up with drop blocks if you want to drop the rear a bit more. If you install new orig springs in the front run them for awhile until they settle in. I found it took a few weeks and then you can set the rear for the rake you want. |
09-24-2023, 02:24 PM | #3 | |
09-24-2023, 02:37 PM | #4 | |
Please keep us up to date as I'm considering the CPP control arms so I can get the castor/camber adjustment correct. Last edited by MySons68C20; 09-24-2023 at 02:52 PM. |
09-24-2023, 05:43 PM | #5 |
My truck has 2.5”’drop spindles up front with new oem height moog springs. Rear has 4” drop, progressive rate springs.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 09-25-2023 at 08:44 AM. |
09-24-2023, 08:58 PM | #6 |
09-26-2023, 07:11 PM | #7 |
70+ ( Old Skool Club )
Didn't say whether you have long or short box truck. Anyway just recently done is my 72 Long bed with a 2 1/2 dropped spingle up front and retained the original springs and control arms etc. Out back like you thought a 4 inch spring drop would give me the look I wanted but back was lower than front when installed so changed them for 3 inch rear springs. Used shock relocators out back as well. Tires are 255/60 17 all the way around. ic on hoist is with the 4 inch rear spring.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-27-2023, 07:58 AM | #8 | |
You sure are right, I didn’t reference the wheelbase. I apologize for that. Mine is a short bed, so I’m hoping I can get a nice gentle rake look. I ordered the CPP kit with the shocks a 0 drop F and 4” drop R and they said that will give me the look I want. I also am running a LS swap which is probably a bit heavier in the front then the normal C10 setup by 50-75 pounds. Worse case I can swap the springs out in the back if it’s not right. |
