Old 10-07-2023, 12:12 AM   #1
yernkie
SUM-760197 four wheel drum brake power conversion
Does anyone have any experience with the Summit SUM-760197 power brake conversion kit? I ordered one on Wed and it arrived today and I thought it came with a new proportioning valve but it did not. I called them and they said I needed the SUM-760186 valve so I placed another order. Tonight I found some install pics online and it looks like some guys are using the stock valve that came on the truck. So my three questions are:
1. Can I use the factory valve and just rebend the lines? Any pros/cons of doing that?
2. Any install tips or tricks? It looks pretty straightforward.
3. Has anyone installed this on an engine with a Rochester 2GV carb? Anything to look out for on the vacuum port or line?
yernkie is offline   Reply With Quote
Old 10-07-2023, 01:29 AM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: SUM-760197 four wheel drum brake power conversion
If you're staying with drums all around, you don't need a combo valve.
Rust_never_sleeps is online now   Reply With Quote
Old 10-07-2023, 12:51 PM   #3
68 P.O.S.
Yes, I would use the factory distribution block for your drum brakes. However, if would have it rebuilt before using it. The combination valve Summit recommended is for disc/drum brakes, not for drum/drum brakes.
Is that kit intended to be used with 4 wheel drum brakes?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-07-2023, 02:29 PM   #4
yernkie
Yes, this was the four wheel drum kit which is probably why it didn't come with a new one. I'll try the factory block and ship back the other. Thanks everyone for the input.
