Old 10-07-2023, 07:31 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Question about American AutoWire Headlight Relay Kit
I bought the American Autowire Headlight relay upgrade kit ( # 500403 ) and wonder if anyone else has installed one of these where did u mount the relays.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-07-2023, 08:19 PM   #2
truckster
truckster's Avatar
Re: Question about American AutoWire Headlight Relay Kit
I built my own but I mounted the relays next to the battery.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-07-2023, 08:21 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Mounted the one from LMC, relays next to battery.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-07-2023, 08:39 PM   #4
Already Gone
Thats what I was thinking, by the battery.
Old 10-08-2023, 01:06 AM   #5
PDXk5
PDXk5's Avatar
I did the same. Here is a pic of where I mounted my relays
PDXk5 is offline   Reply With Quote
Old 10-08-2023, 06:58 AM   #6
I used different kit, but mounted the relays and fues near battery
Old 10-08-2023, 10:07 AM   #7
PbFut
If you are still using the factory battery meter connecting the power source of the headlight to the battery or fuse link block will trick the meter into a charging display. The source of power for the lights needs to be on the other end of the shunt wire. Look at your meter with headlights on and alternator not turning. You should display a discharge. If you have connected to the battery side of the shunt, you will show a charging state rendering the meter worthless when headlights are on.
PbFut is offline   Reply With Quote
