Old 10-13-2023, 12:30 AM   #1
cerial
cerial's Avatar
Removable center section upgrade
Bought a 85 k20 a few weeks back. They had like 1" thick housecarpet covering the floor so yea I am going through and replacing the floors with 1/8" material.
This one does not have the removable hump panel around the sm465/208 shifters. Once I got the carpet ripped out there was a ton of rust. But they also made two 1"8" cuts and bent the hump over towards the passenger side. They riveted it back down covering the cut with duct tape under the carpet.
So the hump is almost completly cut out anyway. What do I need to do to swap it over to the removable style? It there a bottom " ring" I can buy or just make it fit with a top section I have in the barn from another square?
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 10-15-2023, 10:41 PM   #2
cdub2010
Re: Removable center section upgrade
The early style removable center panel has holes in it that bolt down with welded nut on the underside of the cab. Guess you could just use sheet metal screws or go thru the trouble of welding nuts on if you have access.
Drivers side cab bottom of my '77 GMC.
cdub2010 is offline   Reply With Quote
