11-06-2023, 09:53 AM | #1 |
rear tank with lower springs
Went thru the threads but didnt find my answer.
Recent truck I purchased has 5" CPP springs and the bump stops are about 1 inch from axle. If I mount a rear tank from CPP, Im assuming that the bump stops will read on axle tube. DO I HAVE TO DO THE MINI C-NOTCH OR CAN I GO WITH A HEAVY DUTY SPRING TO ACCOMADATE THE WEIGHT OF A FULL TANK? Any help is appreciated |
11-06-2023, 01:34 PM | #2 |
Re: rear tank with lower springs
With only 1" to the bump stops I would do a C notch, or you will be slamming your axel on the frame every time you go over a bump. The ride will be terrible and you will not be happy.
11-06-2023, 02:24 PM | #3 | |
It's Better With Nitro
That's not enough suspension travel in that particular case, regardless of spring rate. Not only will it be highly uncomfortable, but it will be dangerous. I would C-notch the frame if you plan to lower the rear that much.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
