Old 11-06-2023, 01:33 PM   #1
Justin71105
New Door mirror mounting
How did you go about lining up to drill mirror holes for brand new doors. Will be using the stock style 3 hole mirrors from lmc.
The new doors do have the reinforcement but how are you figuringout where to drill holes from outside.
I though about cutting down a center punch and trying to push from inside to give me an idea. Tried looking for a template but came up empty handed so far.
Or putting a jnut on the bracker and threading in a bolt by hand til it touches the door skin. Tap it with a hammer from outside to get a small imprint, back off screw a turn or two and center punch from outside.
1964 C10 Rusto-mod
5.3L - L59
Justin71105 is offline   Reply With Quote
Old 11-09-2023, 09:15 AM   #2
MT65
Re: New Door mirror mounting
I just did this on a client truck, if you check, the factory holes are not square with anything, I checked three different trucks, all the same. I moved the mirrors back a bit to get a better view without the windwing post being an obstruction and leveled the two lower holes to the body line. Epoxy in some weldnuts and its a simple one man job for removing…easier to wax/polish/ buff with mirror removed.
Maybe I’m too picky….
MT65 is offline   Reply With Quote
Old 11-09-2023, 11:33 AM   #3
rideblue00
rideblue00's Avatar
There may be a drawing/template in that yellow assembly manual
rideblue00 is offline   Reply With Quote
Old 11-09-2023, 03:01 PM   #4
MT65
Yes, there may be one there, it will most likely be just like the three vehicles that I checked and be crooked as well, if you want 100% factory that’s your best bet…
Old 11-12-2023, 11:12 AM   #5
Justin71105
Appreciate the feedback, will be attatching a nut somehow so I can take mirrors off easily if needed.
They dont have to be perfect just want to use the inner bracket for some reinforment.
Will likely have someone hold a bolt inside the door and tap the outer skin with a rubber hammer to make a indent to know where to drill.
1964 C10 Rusto-mod
5.3L - L59
Old 11-12-2023, 08:49 PM   #6
MT65
Try these and epoxy them in place, works great
Old 11-12-2023, 10:46 PM   #7
SkinnyG
SkinnyG's Avatar
I used NutSerts to mount my passenger side mirror.
I made a paper pattern of where the driver's mirror was, then flipped it over to locate the passenger holes, then found that the reinforcement inside didn't match.
Having done a LOT of work on my '61, nothing technically lines up on these trucks. I chose not to fret over it. The mirror is mounted.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
