VIN Tag Screw up....Help!
So, in a nutshell, I screwed up. While I was using the stripper wheel I must've brushed it over the VIN tag in the door jamb. It is still legible, but I think it now looks like total crap. there are scratches in the shiny part of the tag. Does anyone have any ideas on how to buff this out?
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
Re: VIN Tag Screw up....Help!
I guess go through the metal polishing process coarse to fine.
I wouldn’t worry about that it’s just a old truck
![]() Join Date: Mar 2015
One could just paint over it like I have seen so many times.
Good news it the rivets are still there. |
![]() Join Date: Nov 2018
Leave it alone and paint over it like Accelo says.
Were they normally painted over? I thought mine was just a repaint or something.
those plates were not painted on any truck i ever had or the truck i have now.here's the plate on my 72 truck now,with original paint on the post,just like it was when it was built.hopefully you can repair it with polishing.
I have a buddy who is a jeweler. I will ping him to see how best to clean it up. I can’t believe I did this….ugh!
Not originally painted but many have been during repaints. I may have the exact year wrong, but I believe in 1980 the vin tags went to the dash on the drivers side to be visible from the outside of the vehicle. Prior to that they were on door jambs, firewalls etc. so some of them just got painted over
The good part is no one would suspect a VIN-plate swap. I know yours isn't swapped but might be a thing to consider for others
![]() Join Date: Aug 2014
And I know folks might want to hear this but you could always remove the tag. Polish it properly, then re-install with the correct rosette rivets. I have done this a couple of times on restorations. They say these rivets are not available but I have found them on ebay at very high prices. And I have never swapped tags. Always put the original tag on the original truck. I just wanted new paint and I wanted it to look new.
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
#13 | |
![]() Join Date: Jan 2009
#14 | |
#15 | |
![]() Join Date: Jul 2000
Rivet heads should look like this:
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#16 |
If it's not a 100% correct restoration it won't matter either way.
#17 |
![]() Join Date: Dec 2009
Polishing oil stones can take care of the edges.
Also jewelery polishing stuff as metioned above. Small broken polishing stones can sometimes be bought on e-bay. Link: https://www.mscdirect.com/product/details/01555853
#18 |
I spoke with my buddy who is a jeweler and he gave me some pointers and told me what stuff to use. I am going to get some polishing wheels for my dremel and see how that goes. I am going to try to polish it with the tag still attached to the truck and see what happens. I will post my results.
Clay
#19 |
I think that will work. Just add elbow grease
#20 |
Well, I am making progress! I picked up some buffing wheels for my dremel (admittedly, I didn't even think about using my dremel :-)) and some polishing compound on Amazon. I have been working my way back and forth and up and down and I think that I have it cleaned up fairly well. I don't think I need to go any further than this, but what the heck, I am having fun!
![]() I have been doing a ton of work on the cab the past few months and have been keeping copious notes and pictures. As soon as I get it all covered in epoxy primer I will update my build thread. Clay
#21 |
looks good,that'll work.
#22 | |
#23 |
Can you take a pic of the attachments you bought for the dremel? I'd like to see them if possible, or you can link to them online if it's easier.
Thank you. |
#24 |
![]() Join Date: Jul 2003
Looks great. I wouldn't go any further with it
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#25 |
![]() Join Date: Oct 2020
That looks really good. Outstanding job!
