Old 01-10-2004, 10:43 PM   #1
jamie72
jamie72's Avatar
OT: What is this??
It says Car Warmer on the bottom. It also says made in Canada. Any ideas on what this is out of? It also has an orginal 110 - 3 prong wall plug in on it.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 01-10-2004, 10:50 PM   #2
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
Uhh.... block heater? I haven't seen one before so I don't know... just a guess.
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Old 01-10-2004, 10:55 PM   #3
Huck
Huck's Avatar
I think the name kind of defines the description of what it does. Warms the car!! DA! Actually it probably mounted under the dash with an extension cord that you would have plugged into an house or garage outlet. You could even have it on a timer so the car would be warm before you had to go start it and freeze your buns off waiting for the thing to get warm. A block heater is usually not much more then a wired oil dip stick. They were and still have common further north---that and synthetic oil.
You could use yours to warm your truck, blazer, or barn!!hehehe
Huck is offline   Reply With Quote
Old 01-10-2004, 10:58 PM   #4
Rooster's 67
Rooster's 67's Avatar
looks like a heater you put in the cab or passenger compartment to warm the inside while parked. does it have any external fittings other than a wall plug?
ChrisK10 a block heater generaly goes into a welch plug(falsely called a freeze plug) on the side of the block and has an element on it to heat the water in the passage
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-10-2004, 11:00 PM   #5
Rooster's 67
huck the "block heater" you speak of is actually just a oil heater to keep the oil in the sump warm and easier to flow on a cold start. see my post above about a block heater
Old 01-10-2004, 11:06 PM   #6
Rooster's 67
go to this link to see an actual block heater. it is for a big truck but it is the same just bigger than automotive applications. the black ring part is rubber and expands to fill the open welch plug hole sealing it to the block.
these will heat the coolant and the oil and the whole block to ease starting, and eliminate the first 30 mins of freezing your a$$ off driving in a diesel truck.
Old 01-10-2004, 11:07 PM   #7
Rooster's 67
oh duh put in the link huh?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452720898
Old 01-10-2004, 11:09 PM   #8
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
...a welch plug(falsely called a freeze plug
I don't know if I would say falsely or not. Most of us know that the plugs exist as happy coincidence. The holes exist due to the block casting process. As it turns out, they might relieve stress if the water jackets freeze and prevent further damage. Generally, they don't do a damn bit of good, but the reasoning satisfied those that asked questions, more often than not.
Hmmm... come to think of it, I probably would say falsely considering I've never seen or heard of an instance where they actually did anything other than leak coolant at the worst possible time.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 01-10-2004, 11:14 PM   #9
Rooster's 67
well they will not prevent a block from breaking if the coolant passages freeze. they are actually called freeze plugs because back inthe day when the blocks were actually made thicker and heavier, the plug would pop before a castin cracked. they were there by called Freeze plugs because they would pop if the block had been frozen. then leaky leaky. and your right shuttermutt, they always rust through at the worst time. or the worst spot. like behind the flywheel.
Old 01-11-2004, 01:41 AM   #10
jamie72
jamie72's Avatar
huck i thought that was what the little levers in the dash was for..one of mine say heat..lol
thinking i might be for a rv or something??
anyway off to e-bay it gos..
jamie72
member #807
www.antlertalk.com
Old 01-11-2004, 07:23 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
We just call them core plugs in the UK.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-11-2004, 09:34 PM   #12
ronh72c10
Hi Jamie:
Huck is right, it's an interior warmer, had one exactly like it in my old 72 Chevelle. Kept me from freezing my butt off when I still lived in Saskatchewan.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 01-11-2004, 10:14 PM   #13
jamie72
jamie72's Avatar
hey ron,how it going??
now how do you keep from freezing you butt off now??
i know its cold down here now..don`t know how you guys up there make it.lol
stay in touch.
jamie72
member #807
www.antlertalk.com
