12-10-2023, 05:41 PM | #1 | |
Conversion Truck Addicted
Converting a non tilt collum to a tilt collum with Delay wipers and cruise
My 81 Crew cab, has wipers on the dash and dimmer switch on the floor and is a non tilt collum
If i want to convert to a later model Tilt collum with all intergrated Has anyone done this swap and how much from a donor truck do i need? the whole dash harness?
Thomas Quote:
12-17-2023, 10:26 AM | #2 |
Re: Converting a non tilt collum to a tilt collum with Delay wipers and cruise
Yes you need the 84 up wiring and 87 truck 88-89 Suburban Crew cab and the Colum with the option you're looking for. ** but your 81metal dash backer for the head light switch is not going to be in right place, no foot button high beam-84-87 face bezel, foot high button highbeam-81-83 face bezel, 88-91 face bezel large radio cut out, 83yr metal dash backer last year wiper on dash, 84yr is the best for cab Colum. But it deepens on the option want fuse box to dash all wiring in the cab the option the better than you will have merge your truck engine wiring with the newer cab dash wining do not cut anything it you want a/c do not have it all the wiring engine bay and cab. lots more work buy truck for the parts is the easist.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
