Coolant overflow bottle ideas
Anyone mount a small coolant recovery set up on the front of the radiator support? Pictures and ideas please. Thanks
![]() Join Date: Feb 2016
Re: Coolant overflow bottle ideas
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
What do you think about this? Think I would find a better mount than the hose clamps.
For my '63 Grand Prix I just used the existing windshield washer bottle.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I had one of these in a '66 Mustang. I used a large "P" style cushioned clamp to mount it. It worked fine.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Where might I find such a clamp?
![]() Join Date: Dec 2009
Amazon has those.
Here's a link below. You just have to get the one for the diameter of your tank. Link:https://www.amazon.com/s?k=cushion+c...sl_6zn8qvi7z_p
Dorman 603-001
This one (DeWitts) is similar to the one in howzzzit’s post. Welded the brackets to the existing reservoir tabs, then bolted to the radiator support.
Wow that looks great! Too fancy for my truck. I am thinking of mounting the Amazon tank next to the a/c receiver on the front sheet metal. I can bring the hose through the hole where the parking light wires come through on a 72.
![]() Join Date: Nov 2022
I got a stainless tank from Speedway Motors. I choose the type that reciculates the coolant back into the radiator.
I am thinking about moving this to the driver's side behind the core support now that I have installed a new radiator. The old radiator in this photo sprung one too many leaks. My wife says it looks like a diamond in a goat's ass.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
Thought about that. How will you route the tubing?
#15 |
![]() Join Date: Nov 2018
This is basically the style I use, mine is mounted on the drivers side between the grill and radiator support.......works for me!
#16 |
I put the Dorman in my 72. Bought it on Amazon. Use one existing hole and drilled another. used a 1/2" spacer for the offset in core support between holes
#17 | |
![]() Join Date: Jul 2003
![]() Quote:
Do you have a pic of the front of your truck with the hood shut? I am curious if that tank is easily seen through the grille.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#18 |
If you want to make the tank black you could use Rit dye. I've dyed many white plastic items black using Rit liquid not the powder. Use the whole bottle and as little hot water as necessary. Let er soak and rinse. Wear gloves.
#19 |
Sheepdip how did you route your tubing? I have an a/c condenser in the way or I would mount it on the passenger side. By the way I'm in Modesto. Can I send you a private message on another topic?
#20 |
Sure can on the private message. My tubing comes back across the top of the radiator as I too have A/C stuff in the way. I'll get a pic tomorrow and post it.
#21 |
Don't have a pic nor the truck anymore. You could audition something (piece of paper) in the area I put the tank to see if you can see it through grill. If so, it was never a concern I had.
#22 |
Anyone know the hose barb size for the Dorman 630-001? I cant find it and they definitely don't answer the phone.
#23 |
I just used the hose from radiator that was on the truck that otherwise was open and just used that on the Dorman barb. Put it through one of the holes, large, that was already in the core support
#24 |
^^^, I have that OER tank in my 67 Camaro. The tank is for a 75 Nova.
The only reason I didn't use it in my 72 (post 15) is because charcoal canister is there so used a Dorman one on core support. |
#25 |
![]() Join Date: Jul 2000
OER 551448 tank with Dorman 82590 cap. Had to use an "L" bracket to support the bottom.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
