Old 12-24-2023, 10:06 PM   #1
h2005frank
250 ci engine
Can a subscriber post on w.t.b
h2005frank is offline   Reply With Quote
Old 12-24-2023, 10:42 PM   #2
dmjlambert
dmjlambert's Avatar
Re: 250 ci engine
Yes, a paying subscriber can post want to buy ads in the parts section or in the want to buy section. Subscribe here:
http://67-72chevytrucks.com/vboard/payments.php
Old 12-24-2023, 11:21 PM   #3
Getter-Done
Getter-Done's Avatar
Re: 250 ci engine
To be a Subscribing member is less than $0.07 cents a day.
I will ask : Where can you get this much advertisement to buy or sell something without the Stuff you have to deal with on MP or other Social sites?
Just my opinion.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 12-24-2023, 11:25 PM   #4
h2005frank
Re: 250 ci engine
Thanks guys for the info guys.
Old 12-25-2023, 02:01 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 250 ci engine
I have a 250 “long block”. It is missing the exhaust manifold, carburetor, thermostat housing, and accessory brackets. If interested, let me know.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-25-2023, 05:57 PM   #6
h2005frank
Re: 250 ci engine
you folks may remember my post several months ago .had coolant seeping from several head bolts.well,took the head off and had it magnafluxed did not find any cracks. head gasket was not leaking because it is not leaking into cylinders.i am thinking the bolt holes in head has a pin hole in the walls.want to keep the inline six in it .looking for some direction.just as soon not put v-8 in it.
Old 12-26-2023, 02:51 AM   #7
MS66
MS66's Avatar
Re: 250 ci engine
Just because coolant wasn't getting into the cylinders doesn't mean the gasket wasn't leaking. What does the oil look like?
I would clean and check the deck surface for cracks and straightness, it should be fine if the engine hasn't been severely abused or overheated.
Next run a thread chasing tap through all the head bolt holes checking for obvious signs of a problem. If it's all good go back with a new head gasket, coat all the head bolts with pipe thread sealer then torque to proper spec.
MS66 is offline   Reply With Quote
Old 12-26-2023, 10:54 AM   #8
h2005frank
Re: 250 ci engine
sorry it took so long to reply having bad lightning storm.ms66 thanks for thinking on this coolant leak problem.tried to make my previous post short.the oil looks good block deck looks good resurfaced head.installed new head gasket and put different thread sealer on all 3 bolts.been driving for about a month and it still runs just fine as it has for past 45 years still leaking.oh yea chased all threads.also just for fun took one bolt out and put thin copper washer under the head of bolt.no change in leak.had a good head of hair till this problem cropped up now getting a might thin.
Old 12-26-2023, 10:57 AM   #9
geezer#99
geezer#99's Avatar
Re: 250 ci engine
Refresh our memory.
Which 3 bolts?
Old 12-26-2023, 11:05 AM   #10
h2005frank
Re: 250 ci engine
standing in front of truck on right side of eng.from front to rear 2nd. 4th 6th the ones out from under valve cover.
Old 12-26-2023, 02:44 PM   #11
geezer#99
geezer#99's Avatar
Re: 250 ci engine
So right above each intake port!
You could try some coolant dye to pinpoint the leaks.
https://www.amazon.ca/LEAKFINDER-LF3.../dp/B07D2M47YV
Old 12-26-2023, 11:40 AM   #12
geezer#99
geezer#99's Avatar
Re: 250 ci engine
Is it leaking out around the bolt heads or somewhere else?
Old 12-26-2023, 01:33 PM   #13
h2005frank
Re: 250 ci engine
Some where right around bolt head.when I drive it the leak is so small that it evaporates the coolant. Only after it cools down can I see traces of coolant.around bolt head.
Old 12-26-2023, 03:44 PM   #14
h2005frank
Re: 250 ci engine
That’s correct over intake ports.i put some dye in it before I took the head off and it just puddled up around the head of bolt could not pin point leak.i tried to stay up late that night and of course it leaked after I fell asleep.i will have to clean the dye up and revisit that procedure during day light hours.maybe need to make my over eng. creeper a little more comfortable so I can lay there longer.thanks for all the time you have taken to respond.
Old 12-26-2023, 10:41 PM   #15
Getter-Done
Re: 250 ci engine
I remember your thread earlier about this issue.
Link: https://67-72chevytrucks.com/vboard/...d.php?t=847551
84 Chevy K-20
Old 01-25-2024, 06:56 PM   #16
h2005frank
Re: 250 ci engine
Don’t know if I responded to 70 stovebolt properly.looking for complete good running 250 closer to me.thanks. Sorry it took so long to respond.health issues had me down.
Old 01-26-2024, 09:42 AM   #17
dmb
Active Member
dmb's Avatar
Re: 250 ci engine
pull the bolts 1 at a time, coat the threads with Indian head Gasket shellac and torque down this will most likely fix your problem.
I coat all the bolts on the heads that I have off. Been doing it for over 50 years.
David
dmb is online now   Reply With Quote
Old 01-26-2024, 10:15 AM   #18
h2005frank
Re: 250 ci engine
That is one I have not tried yet .when I go to town next week I will pick some up .thanks.
