Old 01-10-2024, 11:26 AM   #1
67OLDSTYLE72
muncie 4 spped question
I have a 68 swb 2wd. with a high hump floor pan. the truck came with a v8 and a sm 465 4 speed trans. The question I have is I was planning on putting a low hump pan in the truck that I will cut out of a 2wd. cab, is there going to be clearance issues with the lower floor hump or would I be better off leaving the bolt in high hump pan ? The only other thought is if I stay with the high hump pan will the shifter boot be up to much on the shifter handle and not look right. Any info is appreciated ?
Jay Snyder
Leechburg, PA (Northeast of Pittsburgh)
72 Chevy Cheyenne 4x4 camper special #matching
'71 Chevy Dually 4x4
'69 Chevy Pro Street swb.
'72 Chevy camper special 4x4 402 v8 (not factory) just cool. (truck puller)
70 Chevy swb 400 v8 400 turbo
72 Chevy suburban 4x4, 396 4spd.
68 Chevy shortbed 50th Anv. 327.
72 Chevy 2 wd. Blazer
69 Chevy swb 4x4 327 4spd.
58 Chevy Apache 4x4 swb.
71 Chevy CREW CAB swb 4x4 396 4spd. (just finished)
WE BUY AND SALE TRUCKS AND PARTS
67OLDSTYLE72 is offline   Reply With Quote
Old 01-10-2024, 11:41 AM   #2
425HP409
425hp409
425HP409's Avatar
Re: muncie 4 spped question
I think that the low hump pan would be better as it would have the shifter lever in a more normal height.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-10-2024, 11:45 AM   #3
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
No issues, I did the exact same thing with my truck. I cut the low hump (and a little extra) out of another cab and I actually made the piece a bolt in like the factory high hump, its a little tight, but should clear. It did on my truck. I did add a new lower profile crossmember for the 4 speed. I also recently just swapped the 4 speed for a Tremec TKX 5 speed and other than trimming my shifter hole a touch larger, the low hump still worked.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 01-10-2024, 01:30 PM   #4
67OLDSTYLE72
thank you very much for the pics and description it definitely helped thank you Jay
Jay Snyder
Old 01-11-2024, 07:36 AM   #5
I don't see where you said you are changing the truck 4spd made by Muncie. GM wouldn't have gone to the expense of making two different floor pans if it was not required. Pull you transmission cover off, or just the shifter boot, to see the added height is required to clear this tall transmissions. The only place I've seen a low hump used in place of the high hump is with the TH400 transmission. 4spd trucks in 67-69 weren't available with automatic, so all 4wd models got the high hump. That also allows access to the transfer case shift mechanism located on the top side
Old 01-11-2024, 09:25 AM   #6
67OLDSTYLE72
I am going from a sm 465 truck trans. to a car muncie (m 21).I forgot to mention it in the question that I was going with a car trans.,it was only in the thread starter. thanks for all of the help Jay
Jay Snyder
Old 01-12-2024, 07:19 AM   #7
I guess I missed your reply to Camaro Boy or I wouldn't have posted mine. Looking now I see it's clear you are going to a car 4spd because you would have corrected him rather than thank him. The car 4spds are a direct swap from the 3spd, physically the same dimensions or very close. My '67 GMC project will have an M22. The chassis has the automatic transmission crossmember. The cab is a low-hump already with a hole cut for, I assume, a 3spd floor shift conversion.
Old 01-11-2024, 12:22 PM   #8
RichardJ
Calling a transmission a Muncie isn't a very good description.
>>The Synchro-mesh 465 or SM465 is a heavy-duty, four-speed manual transmission built by General Motors for use in light and medium duty trucks from 1968 to 1991 at the factory in Muncie, Indiana; it was designed to replace the somewhat similar Muncie SM420 transmission, which had been in production since just after WWII<<
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-12-2024, 07:39 AM   #9
I missed your reply to Camaro Boy before mine where you would have corrected him if you weren't going to a car transmission. It all makes sense now. Primo collection you have there. I don't know if we're crossed paths before, but I see you didn't start getting with these trucks yesterday
Old 01-12-2024, 10:53 AM   #10
palallin
My '67 started life with PG, but I put in a 3sp and then a 4spd (M 21). That SWB truck was a good example of a truck that could live with a car 4spd.
My '69 LWB 4x4 still has the truck 4spd (M465) it was born with, and I wouldn't trade it for anything ever put in a car.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 01-12-2024, 02:59 PM   #11
67OLDSTYLE72
Yes been at it since 1984 when I graduated high school, I move a couple trucks or parts a year at Carlisle and the local parts a rama near me. I am sure we have ran into each other some where along the line. We are always outside of gate 3 at the corner at Carlisle, if your ever there or out this way stop in and we can bs about the trucks. I appreciate everyone's help Jay
Jay Snyder
Old 01-18-2024, 12:54 PM   #12
1967GMCC20
1967GMCC20's Avatar
NP435G 4spd, not sure of torque rating is STD high hump in my 67.
1967GMCC20 is offline   Reply With Quote
