Revitalizing a 6T C10
![]() Join Date: Aug 2017
T5 / sbc
Hey All,
I am trying to piece together some functional parts to get Rusty back on the road ... and I was hoping to run something by the great minds here and make sure I have all my bases covered. I have a 350 that we rescued from the Craigslist (14010207 block - 80-85 "truck" motor) that I was able to hear run on a test stand and a rebuilt T5 (26 spline) with a warranty and now I've got the job of joining them together ... I am hoping to keep using a hydraulic master cylinder ( I have Capt'n Fab's brackets and those components) I was trying to find a kit that covers it all, and I found this : https://www.jegs.com/i/JEGS/555/6008...UaAl7DEALw_wcB or this questionable amazon offering : https://www.amazon.com/ClutchMaxPRO-...evrolet+Camaro will this kit plus some new flywheel bolts help me bolt this all together? Is there anything else that I would / should need or does anybody else have any other recommendations?
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... Last edited by 60short; 01-31-2024 at 03:08 AM. |
driving is in my blood
Re: T5 / sbc
Its just a clutch kit, any for the application will work.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Re: T5 / sbc
What Tom said. Just use the clutch kit for the 350. You will likely have to drill out 2 holes on the T5 to mount to bell housing. Other than that it should work.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Re: T5 / sbc
Re: T5 / sbc
What do you have now? bell housing, fly wheel, pilot bearing etc. My '54 3100 came with a granny gear cast iron 4 speed. I used every thing except, I replaced the clutch disc with an 11 inch disc for an Astro van. It's the only part I bought. Good info in the above post. I wish I would have had all that info in one place when I did mine.
#6 | |||
Re: T5 / sbc
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
Re: T5 / sbc
If not a "World Class" T5, go easy on her as you are likely right up against the torque limit!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
Tags |
clutch, t-5, transmission |
