60-62 bell housing color
Does anyone know what the correct color of the manual bell housings were on the 60-62?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
![]() Join Date: Mar 2006
Re: 60-62 bell housing color
My bellhousing was medium gray - same as the 235…
Depends on the engine, 235s were medium gray.. V-8s were Chevrolet Orange... "Big" sixes, I'm not sure....
![]() ![]() ![]() Join Date: Jan 2018
For the US 60-66 trucks, 283s were gray, the 327 in 66 was very close to Detroit Diesel Green (forget exact name at the moment). Chevy Orange didn't hit the US trucks until 67
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() ![]() Join Date: Apr 2012
No orange engines in any 60-66 Chevrolet trucks from the factory . 283 was gray and 327s green in 10-30 series
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
![]() Join Date: Sep 2016
My 62 suburban 235 was a green.
Active Member
![]() Join Date: Sep 2023
I wanted to check to see if they were painted the engine color or just cast. My 235 had gray on it but most of it was worn off. So I couldn’t tell for sure. Im building a 350 to replace the 235 and it will be Chevy Gray like the 283s had in these trucks. So now I’ll paint it to match. Thanks for the help!
#10 | |
Yes. I got it from KBS coatings. I brushed the block and sprayed the oil pan and valve covers. Since these trucks had gray and green engines I wanted to stay with one of the colors.
Do you still have the 6 cylinder that was part of this Bell Housing ? Reason I ask is , the 261 Six that was optional 60-62 was green , 235s were gray
No I dont have it just always thought it was a 235. Never tore it apart to find out. Might have been a 261
I bet you have a 261. My 235 was gray.
