Optima Recharge
I have an Optima Yellow Top from 2007 that is holding a 13 plus volt charge. I have a Red Top from 2015 that was holding a good charge but is now down to 10.5 volts and will not charge higher. The Yellow one did this for a while but snapped back with a battery tender. I tried that with The Red top but no Dice.
Should I just give up on these buggers or does some have a magic bullet?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
![]() Join Date: Jun 2002
Re: Optima Recharge
Some of the newer battery chargers will not charge a battery if the voltage drops too low. If you have an older charger you may be able to use it to get it up (assuming no shorted cells or battery defects). If I have a problem battery I breakout my grandfathers charger and let it go for about 2 hours. That thing will cook a battery if you don't watch it!
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#3 | |
![]() Join Date: Sep 2014
Re: Optima Recharge
Set the old school charger to the lowest amp setting (mine is 2 amps) until you see 12v and then switch to the smart charger. Keep an eye on it and make sure the battery is not getting hot! |
Re: Optima Recharge
the yellow top is back when optima was here and made awesome batteries.
the red top is when they went downhill and are in the place they are in now. You can try your tender on one and then hook up battery cables to the other and that will equal the voltahe and let that tender do its job for a few days. of course ++ and -- the tenders take a while when doing repairs, so with two battreis itll take some time. After a few days unhook the battery cables and try only charging/repairing the red top. But, in the end, optimas look cool, ands that is a big reason every oned them, but nowadays there are better ones out there. Look up XS batteries.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
#5 | |
![]() Join Date: Dec 1999
Re: Optima Recharge
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 02-11-2024 at 01:59 AM. |
Re: Optima Recharge
I don't have an old school charger. I have an old trickle charger for remote control car batteries. I bet that is low amps. Trouble is that its on a timer. I could probably zip tie the dial. Thank you all for responding. Will keep you posted. Has anyone tried the actual Optima charger? Expensive...
#7 | |
Re: Optima Recharge
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Re: Optima Recharge
I can't seem to get the Red Top past 10 volts. It gets warm too. I think it's toast.
Re: Optima Recharge
Well I gave it another shot. I connected the positive to positive and negative to a standard battery and then hooked up a battery tender to each of the batteries. The Harbor Freight 10 dollar kind. The Red Top is now taking a charge and holds about 12.4 volts. I have not done a load test on it but so far so good. Stay tuned for results.
Re: Optima Recharge
Well I checked on it this morning and it is back down to 10.7 volts. I am going to try a slight discharge and recharge to see if that works. Just experimenting at this point.
