02-22-2024, 09:40 AM | #1 |
Check Engine Lite. No Codes
Hi, I am doing a 57 chevy pickup with a 6.0 LQ4, 4L80E. I also have a Dakota Digitial Dash with the BIM module to pick up data from the PCM for the dash. I got the truck started only for about 15 seconds and the check engine lite is on with no codes stored. I did unplug the PCM and reconnected power and the check engine lite is not on so that tells me the wire to the lite is not grounded. Has anyone ran into this? This is the first LS conversion I have done so all new to me. Thank You Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
02-22-2024, 04:28 PM | #2 |
Re: Check Engine Lite. No Codes
Don't know what PCM you are using but on the RED-BLUE connectors the MIL light is pin 46 on RED. It supplies ground to the light. Hope this helps..if you have a scanner that reads live data your can check the status of the MIL light on that as well.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
02-22-2024, 05:33 PM | #3 |
Thanks for the information. Mine is a Blue and Green Connector with DBW. I do have a Chinese knock off tech 2 and a acron code reader and will check status of lite. I know it will store codes as I had a fuel pedal code which was my error. Just a odd one. Thanks Steve
03-04-2024, 10:10 PM | #4 |
Hi, I figured out why the check engine lite was on without codes. I am using a Dakota Digital RTX cluster which has a check engine lite. The LED light needs to see some kind of load so had to hook up a separate lite and this corrected the problem.Steve
03-14-2024, 08:24 PM | #5 |
Roto Reuter thats the name...
Hey neighbor. I'm nearby from Darien, NY. Wish I would've seen this sooner. I ran into the exact issue as you and solved the problem by putting in a small light to take some of the load. Problem solved.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-15-2024, 09:08 AM | #6 |
Thanks Neighbor, I reread all the Dakota manual and there was information on it and that's how I found it. I guess it like adding led exterior lites. Steve
