Steering linkage question
Working on the steering of my project '64 C10. It has a GM power steering box, typical 70s-80s outside of frame, with a mounting adapter plate (the 3-bolt type), I'm assuming the box's original pittman arm and 64 center link, spindles and a-arms. The tie rods I purchased (for a 64) don't work. With the steering box/wheel adjusted centered, right wheel can be adjusted tie rod-wise (though the rods are adjusted WAY out), and the left wheel can't be adjusted (rods are all the way in). I read a post by Capt.Fab saying he uses 73-87 steering components on his setups. I'm assuming he means the tie rods, center link and idler arm. Is that what you use with the GM PS boxes, with everything else stock for the year?
Last edited by 72Mountaineer; 03-24-2024 at 11:12 AM. Reason: original was confusing, no replies |
Re: Does it fit?
My friend Jay made this how-to for power steering that shows how to get the center link and tie rods centered.
https://lugnutz65chevystepside.weebl...-steering.html
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: Does it fit?
I used all 73-87 on my swap. But your issue seems a little odd. Is this on a fresh build?
Id double check your center link isn't flipped as well as control arms. Sounds silly but it happens.
"Just do it! Dont let your dreams be dreams" -Shia LaBeouf |
![]() Join Date: Mar 2015
Re: Does it fit?
"Id double check your center link isn't flipped as well as control arms. Sounds silly but it happens."
Nuts go on from the front of the truck on the center link. I did it, seems the logical way it would work during the assembly. Then had the alignment done twice. Alignment shop didn't catch it, they even drove it! Guys on the board sent me in the correct direction. Third alignment was a keeper. Note; If it's reversed the truck will easily push straight, but as soon as you turn it will be like the brakes are applied. |
Re: Does it fit?
Not 100% sure, but I believe using 73-87 components need to have the idle arm relocated to match the longer 73-87 pitman arm?
Re: Does it fit?
Not a fresh build, but a project I acquired a while ago. The center link is correct, with the tie rod nuts on the outside. I purchased a steering box mounting plate from Capt. Fab, as I think this is the root of the problem. I watched a few Youtube vids and realized the location of my steering box is way (about 1 1/2") forward, which should make my tierods in a much better location. Thanks for the replies.
