Old 04-24-2024, 11:57 PM   #1
5150
C10 Club Tennessee
5150's Avatar
1955-1959 Inner Fender to Cab Brace.
We bought a truck that was in pieces and we're trying to figure out where these pieces go. Pics would be very helpful.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-25-2024, 01:29 AM   #2
popeyestruck
popeyestruck's Avatar
Re: 1955-1959 Inner Fender to Cab Brace.
Goes on the firewall . Should be 2 bolts that are riveted on that match up
popeyestruck is offline   Reply With Quote
Old 04-25-2024, 09:02 AM   #3
dsraven
they bolt up to the firewall and hold the inner fenders down low near the frame. they go on both the same direction, not like a mirror image side to side. I forget which way they face but they both face the same direction, you may have to check the assembly manual for that tidbit.
dsraven is online now   Reply With Quote
Old 04-25-2024, 09:43 AM   #4
5150
C10 Club Tennessee
5150's Avatar
Unfortunately, there are no holes on rge firewall that match that. That's what originally thought.
Bryan
www.gmtruckshow.com
Old 04-25-2024, 09:49 AM   #5
dsraven
is your firewall a stock one or has it been replaced or repaired at some time? there would be studs sticking out on the engine side if I remember correctly. you could look on the inside for where they would be spot welded on as there would be some marks but, in reality, if there is nothing on the engine side that lines up in the area where the inner fenders have the hole for the rubber grommets and inserts then you will need to make your own mounts. the assembly manual has a diagram showing the firewall and all the dimensions for holes, and mounting points.. it is a free download from the trifive site. google
55-59 chevrolet truck factory assembly manual
and click on the trifive site. i suggest to grab a copy of that on a thumb drive or in your documents if you are in the assembly stage, or the dissassembly stage, or in the I wonder stage, etc
Old 04-25-2024, 02:00 PM   #6
unclebrad
unclebrad's Avatar
Here is what they look like on my 55.
55 Cameo w/ 409/700r4
unclebrad is offline   Reply With Quote
Old 04-25-2024, 04:03 PM   #7
_Ogre
_Ogre's Avatar
my pictures concur with unclebrad and dsraven. same direction
shop air compressor timer
Old 04-26-2024, 12:31 PM   #8
57tailgater
From factory assembly manual.
57tailgater is offline   Reply With Quote
Old 04-27-2024, 02:21 PM   #9
_Ogre
_Ogre's Avatar
note the spacer on the bolt, so that you can snug up the bolts without squeezing out the anti-squeak rubber washers. a piece of 3/8" tubing will do in a pinch.
