01-13-2004, 01:46 AM | #1 |
another stupid drop question
I am doing a 5/7 on my GMC & am gonna be using a flip kit on the rear. My question is what is the best way to do the other 2"? Front shackle perch relocate & rear shackle or a 2" block.
I told myself when I started this project that I'd make as many of the parts myself as I could. If I modify my rear shackles, do I just add 1" of metal to the shackle to = 1" of drop or if Im gonna go through the work, go ahead & just drop the other 2" in the shackle & then what happens to the pinion angle? OK, I'm done with the dumb questions now, well at least until the next one...corn |
01-13-2004, 10:13 AM | #2 |
Trucker.
If you did the front hanger(2" drop) and rear shackle(1-2" drop) you'd end up with an 8-9" rear drop. I'd suggest the shackles due to ease of install.
01-13-2004, 10:22 AM | #3 |
I thought the front hanger was 1" ! Thanks. Anybody have a set of 2" shackles layin around that they can measure (bolt hole to bolt hole) for me?...corn
01-13-2004, 10:25 AM | #4 | |
Trucker.
01-13-2004, 11:17 PM | #5 |
or you can just remove a few leafs to get a little more drop! cheap and easy!
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! |
01-13-2004, 11:43 PM | #6 |
forgot all about that. DOH...Thanks
