05-27-2024, 11:34 AM | #1 |
'63 brake conversion analysis paralasis
I'm stuck in what to do. I ordered some parts with one plan, now I'm considering something else and need some help.
My '63 is about to get a power disc brake upgrade. It's just my around town truck, C10, static drop front with manual airbags in rear, inline 6, nothing crazy. There isn't a small block in it's future. I picked up a '75 complete crossmember to swap in and ordered CPP CP30106-4 spindles for the 75 crossmember, plus 6 lug rotors. Now, as I'm getting ready to swap the control arm bushings, I'm thinking I might want to go ahead and do tubular control arms instead. In that case, I can't figure out if the CPP spindles will work with the 63-70 tubular control arm ( 6370TCA-ULK-B ) or if I'll need to go ahead and swap the crossmember if I want to use those spindles. Or would it make more sense to use the 63-70 tubular control arms and just get the correct spindle? I feel like I could probably run the 63-70 tubular control arm and do a ball joint change to use the spindles I have. Thanks for any help you can give. |
05-27-2024, 02:55 PM | #2 |
Re: '63 brake conversion analysis paralasis
Why don't you get tubulars for the 73-87 spindles you have already.. no reason to go backwards and install 63-70 balljoints.. plus the squarebody parts will be more readily available compared to 63-70.
Also you do not need to swap the entire crossmember .. squarebody arms will bolt right up to the 63 crossmember upper and lower.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
05-27-2024, 03:19 PM | #3 | |
I thought this would work, but couldn't remember which would be the easy route. A decade ago I could recall it off the top of my head, but the truck has been parked for awhile. |
05-29-2024, 04:55 PM | #4 | |
05-27-2024, 10:52 PM | #5 |
Are the tubular ones made in China? If so I'd just keep the the GM ones.
05-27-2024, 11:35 PM | #6 |
If it is just an around town truck do you need new tubular A arms?
05-28-2024, 07:43 PM | #7 |
05-28-2024, 10:25 AM | #8 |
I think this is the easiest way to do a disc brake swap. Like Bagger said.. Do you really need tubular control arms for just around town. http://67-72chevytrucks.com/vboard/s...d.php?t=727826
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-28-2024, 07:47 PM | #9 | |
For some reason, I think there's an issue with one of my arms, or maybe it's just a ball joint. It's been parked over 20 years, with occasional bursts of progress. I'm finally at a point where I can get it done. |
05-28-2024, 10:11 PM | #10 |
[QUOTE=floormonkey;9314885]No, I probably don't. So you just swapped ball joints, used original arms?
Yes. CCP sells the tie rod center with two different sizes to accommodate the early and later model tie rod.
