05-28-2024, 10:16 AM | #1 |
67-68 Reproduction Hood
Morning all!
I have been trying to work out the warpage and "oil canning" on my hood, but to no avail. There is a ton of warpage that I just can't seem to get out. I am wondering if it would be best to just replace the hood altogether. In reading through some older threads, it would seem that the hoods were hit and miss in the past. I even saw that GMC Paul's would not sell the 67-68 hoods due to fitment issues. Then it looks like in 2017, he started to sell them, but I could not find them on his site. Am I out of luck, or should I roll the dice on a repop hood? Thanks, Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
05-28-2024, 10:48 AM | #2 | |
Re: 67-68 Reproduction Hood
https://www.premierstreetrod.com/det..._Standard.html Good luck! j
White K20 |
05-28-2024, 10:57 AM | #3 |
Thanks Jeff! I will give them a call.
05-28-2024, 01:48 PM | #4 |
There are a few hot rod shops out here that build these things and get good bucks for them. You should pick three local shops, call them or stop by. See what they have to say... you will be glad you did. Most builders don't participate in these forums. You need to catch them at a car show or ambush them at their shop or on the phone. All are good dudes and will share info. Maybe even do your hood for you.
j
White K20 |
05-28-2024, 01:54 PM | #5 | |
Clay
05-28-2024, 02:29 PM | #6 |
You could always back off from semi- perfection and go the semi-patina route. Checkout the May edition of CK Truck Magazine. They have a multi page layout of a shined up (semi-patina) truck with dents and scratches. They rave about the truck, no article or verbiage about the build, just a multi page photo layout. Pretty interesting the way everyone looks at classics and body work and paint now. Check out how much this K went for on BAT. Anyhow, good luck with the new hood. You will get there soon, I'm sure of it.
https://bringatrailer.com/listing/19...-k20-pickup-3/ j
White K20 |
05-28-2024, 02:35 PM | #7 |
Who Changed This?
Go over here-
https://www.allmetalshaping.com/index.php And ask around. This is a nice bunch of people who can steer you right, with your hood.
05-28-2024, 02:43 PM | #8 | |
I think that I am too far in at this point to go with the Patina look. :-) In retrospect however, I would have gone that way to just get the truck up and running. I would have been driving it by now.
05-28-2024, 04:37 PM | #9 |
I helped out a fellow member, here, a couple of years ago. I had 2-67/68 hoods. He had bought a cowl induction reproduction hood, and tried to make it work. he may have scrapped it, it was so far off from fitting. He was thrilled to get my hoods....
05-28-2024, 05:40 PM | #10 |
I put a reproduction 67/68 hood on a truck. I bought the hood in the Dallas area from a guy on craigslist that was in the business of selling sheet metal. The one I got had a small dent so I got a deal.
I was going to just strip and paint the hood on my 68 and when I pulled the front trim off it had tons of rust holes. I was up to my ears in bodywork and had already metal worked the rest of the truck and didn't want to stop and fix the factory hood. I got the repop and it fit up to the factory fenders really nice, not perfect, but good enough. The thing that bugged me majorly was there is a small scallop at the front of the the hood that the repops don't have. The front angled surface of the repops is flat all the way to where it bends to the horizontal part of the hood. Once I was done with the truck, it was job one to get the factory hood repaired and painted. I gave the repop to a boardmember and last time I was at his place it was laying in the bed of one of his other trucks. |
05-29-2024, 01:53 PM | #11 |
I am still in the middle of getting my 68 stepper truck restored. I bought a new re-pop hood a while back and looked it over and took measurements against my old hood and it appears to be spot on. I cannot remember off-hand who I bought it through, but I will go and look at the box at my first opportunity. I have been having great luck with replacement panels and patches. The fitment issues may be a thing in the past with the better known brands. I would avoid the low-buck Chinesium knock-offs though. I think it is a TriPlus hood. I would also look into if Key Parts makes a 67-68 C10 hood.
05-29-2024, 04:24 PM | #12 |
Well, I found a hood yesterday on Craigslist. It isn't perfect, but it isn't all that bad either. Worse case scenario, I will go with that one. I have been hammering away at the original hood and have done a sh!t load of heat shrinking, so I think I have all the oil canning out of it. I am going to now put some filler on it to see what happens. Like I said, worse case scenario is that I will go with the other one. I think that I will abstain from the repops for now.
Clay
05-30-2024, 10:23 AM | #13 |
Clay, Did you fill between the hood skin and the supports on the inside yet? Or do you plan on using the foam strips that are available?
I used "3M NVH Dampening Material 04274" to fill between the skin and supports. I hung the hood upside down from some hooks on the supports, so the skin was free hanging to apply the material. Made a great improvement in the skin moving or feeling like it was oil canning. |
05-30-2024, 11:01 AM | #14 | |
Clay
05-31-2024, 07:34 PM | #15 | |
Who Changed This?
