06-03-2024, 05:13 PM | #1 |
Painting the cab
I am getting pretty close to painting the cab. I have to finish final sanding and then I plan to seal everything with a thinned epoxy (eastwood) followed by single stage paint. As I am doing the entire cab inside and out the same color, should I paint it in stages (inside first, let it dry, then outside)? Or should I do the entire thing all at once?
Thanks, Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
06-03-2024, 05:42 PM | #2 |
Re: Painting the cab
I would definitely break it up in stages. Paint the inside. Then back mask and seal the window openings and door jams, at the pinch welds.
06-03-2024, 05:45 PM | #3 |
That makes sense. Would it be better to only seal the inside, paint that, back tape the cab and then repeat for the outside? IOW, only seal what I am painting at that time?
06-03-2024, 05:55 PM | #4 |
Yes, generally you let the sealer flash then then go right to paint. The tech sheet should give you the specs for that. Depending on the product, you will have a window by when you need to start spraying the top coat by. Or, you will need to re-sand the sealer, and start over.
06-03-2024, 08:38 PM | #5 |
As said above interior first and then back mask. Then the outside. That way you won't be dragging an air hose across new paint to get at the interior.
06-04-2024, 11:53 AM | #6 |
Ok, thanks everyone! Hopefully I can get this thing in some color soon.
Clay
06-04-2024, 12:53 PM | #7 |
What color are you painting it ?
Are you also using Eastwood single stage paint. If not, I would recommend using that paint manufacturers sealer. |
06-04-2024, 04:54 PM | #8 | |
Clay
06-05-2024, 12:49 PM | #9 |
Sounds great !
