Old 06-03-2024, 11:40 PM   #1
Orange Crate
Orange Crate's Avatar
Hydro-boost with Disk/Disk Prop Valve
My disk/disk hydro-boost conversion proportioning valve turns the "brake" light on when applying the brake. This is a new first installation/test in the garage. I had selected a disk/disk proportioning valve when putting it together but it is obviously not the correct combo. So anyone with hydro-boost have a part number for a proportioning valve that works? I used the search function above with lots of info but non with a hydro-boost added in. The system has been bled numerous times and the light can easily be reset. I'm not looking for trouble shooting info unless you have hydro-boost.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 06-04-2024, 02:51 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Hydro-boost with Disk/Disk Prop Valve
I don't speak hydroboost, but the type of assist should have nothing to do with the combo valve, which only interacts with the MC. Boost only changes the amount of pedal pressure it takes
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is online now   Reply With Quote
Old 06-04-2024, 05:34 PM   #3
HO455
HO455's Avatar
I'm in the same camp as Rust_never_sleeps. The valve is shifting off center due to a pressure difference on the piston, inside the valve. Whichever side the piston is moving to is the low pressure side. Whether the low pressure is from a leak, or trapped air in a caliper, or possibly low pressure from the master cylinder is what you need to figure out. A brake pressure guage should help locate the problem.
Some rear disc brake calipers can be notoriously hard to completely purge of air. Sometimes the caliper has to be removed from the mounting and a plate inserted to mimic the rotor and then while the caliper is held so the bleeder is in the absolute upper position the caliper is then bled.
Good luck.
RIP Bob Parks.
Old 06-04-2024, 09:05 PM   #4
Orange Crate
So I thought I would start with a known good part number for the prop valve from someone whose hydro system already works, and go from there. Like I said in the first post, I searched on here a lot and the nightmare stories of bleeding gallons of fluid set me on the part number first.
Old 06-04-2024, 10:06 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Caddy park brake calipers? A friend has been fighting a similar issue.
Was told the re pop caddy calipers are not the best.
He's switching to a later model mustang caliper kit.
Old 06-05-2024, 12:15 PM   #6
Orange Crate
OK so I need two new rear calipers because a friend was told they were the problem? Is the "friend" on this board? If so maybe you could convince that person to log in and give everyone the real scoop (with pictures please, because everybody likes the pics...) I'm asking for a friend....I'm going to go broke if you guys keep spending my money like that, oh wait I need a brake pressure gauge too! I wonder how much a known good part number will cost me....
Old 06-05-2024, 01:41 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
It's on a oldsmobile.
Was relaying his experience with repop cad style rear calipers.
Pv4 is the standard name for disc disc, as far as a oem pn sorry.
Old 06-05-2024, 02:12 PM   #8
Orange Crate
An Oldsmobile with hydro-boost? I guess I'm not too sure how re-mfg calipers are the cause of a brake light AND he decided to get rid of them for another style? Were they leaking? I get that some calipers are hard to bleed but to give up on a set, they must have been really messed up. What was wrong with them specifically?
Old 06-05-2024, 02:12 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
3667810 gm
Try this..
Old 06-05-2024, 02:26 PM   #10
Orange Crate
3667810 gm
Try this..
So that is the one your friend has on his disk/disk hydro-boost system that works?
Old 06-05-2024, 03:58 PM   #11
fun in dirt
fun in dirt's Avatar
I just used a universal, manual adjust, valve in the rear brake line. Don't remember exact brand without looking at it, but similar to this https://www.summitracing.com/parts/leb-apv02 . But I did pair it also with a new master cylinder off '01 Chevy with disc front & back.
Been working for 10yrs now with zero problems.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 06-05-2024, 04:48 PM   #12
Orange Crate
Congratulations on being the first with hydro-boost to reply. I would have thought more people would have already converted seeing how easy it is. Ya, looking at manual adjust valves the last couple of days. I have the stock disks/ calipers on the front D60 so they are close to the stock D44 rotors. D60 at 12.7 diameter and D44 at 12.4. not a big change there, but could need pressure adjusted because of that. The major difference is the width, D60 at 1.625" and D44 at 1.25". Some nerd info, the rear disks are actually the front disks from the old D44. I'll put a cab over camper on this Camper Special so I think I'll like the extra heat dissipation, although the original set up seemed to work just fine for over 40 years. Here is the old camper and the old "guard" dog.
Old 06-05-2024, 11:56 PM   #13
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Yeah tell me how easy the Hydroboost is again. You can't seem to get it to work. Then you seem to have an attitude towards those that have replied. Good luck. As said already the type of booster dhould have nothintg to do with what proportioning valve ypu would need.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 06-06-2024, 11:18 AM   #14
Orange Crate
Fair enough. Here is a quote I think may help....
"Super excellent info, much appreciated."
I will call out BS when I see it, just for future reference.
Old 06-06-2024, 11:49 AM   #15
jeffahart
jeffahart's Avatar
I would leave it alone until you drive the truck. See how it brakes and stops and if like the bias and all else is good in the stopping/braking arena; then chase the light problem. You could get the light working with a new valve and not like how it stops. It will be a good point of reference ,anyhow, if you need to move onto a different valve. I'm running a disc/drum so I won't post the part. Hydro-boost is a great upgrade.
Good luck... Have fun!
j
White K20
jeffahart is offline   Reply With Quote
Old 06-05-2024, 05:37 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
After his brakes wouldn't bleed, he took to a shop.
They told him the re pop calipers are a pita to bleed/adjust.
And still won't be good.
So swap to a more modern system is his solution.
You ever think a metric non park brake caliper to see if it's a proportioning valve or caliper issue ?
Old 06-05-2024, 05:47 PM   #17
Orange Crate
Non of that makes any sense....
So now I need MORE calipers? Maybe it because they would be metric....ya, that's it.
Old 06-05-2024, 08:29 PM   #18
LS short box
On my 66 Mustang project with a hydro boost unit I used a Wilwood adjustable prop valve in the rear brake line. I used C5 Corvette disc brakes all around so not apples to oranges but the Wilwood prop valve once adjusted worked perfect.
Not a great pic but hard to see underneath the master.
One thing I had to add after installing the hydro boost was add a fluid resisvoir with a filter to eliminate micro bubbles. This per the folks at Hydra-Tech.
Old 06-05-2024, 09:11 PM   #19
Orange Crate
Super excellent info, much appreciated. So where exactly did the extra reservoir go? Which system was it plumbed in to, the master cylinder sys, or the hydro sys? Gold star for the nice Stang!
Old 06-06-2024, 11:52 AM   #20
Joyridin
I have a hydro boost on my truck running for about 3 years now. I don't even have a proportioning valve. I have never had an issue with the brakes locking up or being off balance. I have an adjustable prop valve I originally planned on installing on the rear like fun in dirt has, but I never got around to it. All it would do is stop the rear from locking if that were an issue.
I do not have the parking brake in the caliper. My PB resides inside the rotor, so I am using Explorer calipers. I have never had a problem bleeding rear calipers with the PB in them. The trick is having to pump up the parking brake lever to get the pad adjusted correctly or you will never got a good pedal. The rear caliper has a ratchet mechanism which pushes out the piston reducing travel. Once you have that set, then the piston has only a very small amount of travel. Whether that small amount will mess with your prop valve, I am not sure.
Joyridin is offline   Reply With Quote
Old 06-06-2024, 12:36 PM   #21
Orange Crate
Yes these calipers can be rascally. I have them set up OFF the rotors with a block of wood the same thickness as my rotors between the pads. This way I have the bleeder at the top (which, when installed, the bleeder is not the high point). Also using a small brass hammer to help collect the bubbles. Ok, gold star faxed....
Old 06-06-2024, 01:19 PM   #22
jeffahart
jeffahart's Avatar
If you set your brakes up right, the rear brakes will lock up on panic stop. But if you do a panic stop at 34-40 mph with the weight of the camper on the rear... it will plant your face in windshield and catapult your camper over the cab(ok, a bit of an exaggeration) but it will stop better with more weight on rear axle and can put your face into the windshield. Keep that in mind when you dicker with the brakes and no camper. Your biggest concern is slowing down with the camper. But you already know that.
j
White K20
Old 06-06-2024, 01:43 PM   #23
Orange Crate
j
Yes, have already experienced the "launch" through the windshield the first time I got to drive it around the garage (big circular driveway). I have seen (I don't know where) a set up that has an extra bias valve attached between the rear axle and the bed floor with linkage. Added weight squats the bed some and through the linkage changes the bias more towards the rear. I was thinking about an adjustable valve just for ops with the camper installed.
Old 06-06-2024, 02:35 PM   #24
67 twins
If I remember correctly(and I may not) GM trucks from the 80s had this before they,went to ABS
Chris
Old 06-06-2024, 09:20 PM   #25
LS short box
On my Mustang project I didn't have power steering so just one resivisor for the hydro boost. With the C5 discs it would put your nose up against the windshield until you got used to it.
