Image-Correct inside mirror 69 CST20?
Would’ve thought by ‘69 Inside rearview mirror would be standard on Chevy trucks? I guess not, All of the interior paint on my 69 is original and the area above the windshield has never been drilled, never been a mirror there. Could one of you post a picture of the correct mirror? Not sure it would make a difference, My truck is a CST20, Are the mirrors different between a base model and top of the line interior?
Steve weim55 Colorado |
![]() Join Date: Jul 2003
The inside rear view mirror was an option on early 1969 trucks. It was option code D36.
See this SPID from a 1968 for example: and from an early 1969: What the early bracket looked like: Mid year 1969 used the bracket with the grained vinyl cover and stainless steel backed day/night mirror that was also used in 1970 and 1971.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 07-01-2024 at 02:14 PM. |
Re: Image-Correct inside mirror 69 CST20?
1970CST - thank you for the information! The early 69 mirror mount that you posted looks very similar to the one on my 65 where it screws to the windshield header but different where the mirror mounts to the post. Makes me wonder if that is a one or two year only mirror mount? That was certainly Help in my search…..
Junior Member
![]() Join Date: Feb 2009
I guess this would apply to my 68 GMC Super Custom as well. It has the mirror on the glass and no stamped or raised area in the roof. I thought everything pre-72 had the roof mount.
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
Born Psycho
![]() Join Date: Feb 2001
the only year with the raised area for the mirror was 71.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
I have this style and never knew that it was adjustable, every time I go to use my sun visor it hits the mirror. Now I can get out there and adjust it, I was about to replace the hole arm.
1972 C10 Step Side short bed |
![]() Join Date: Apr 2016
I wonder if camper trucks were the ones that had no in-cab rear view mirror. This is interesting. If I were adding a mirror and the cab roof were not drilled for it, I would go for the 72 type glue-on-windshield type.
#8 | |
![]() Join Date: Feb 2002
When I bought a '67 K/10 Suburban, the PO had either put in a '72 Windshield or glued on a mirror. It bounced enough to be useless at speed. Lucky for me, I had cannibalized a mirror mount just like Pic 3, in Post #2, when I totalled my Dad's '64 Olds Wagon, years before. It was just like the one in my '68 C/10 Stepside, but chromed. [While the C/10's was black.] I held it up to the center of the windshield header and marked the holes with a sharpy. Drilled 3 holes, and screwed the mirror mount in place. Worked great, and the image didn't blur at speed.
![]() Join Date: May 2010
The 1969 bezels/boots were unique to 1969. Below is a link to an old for sale thread that shows the correct style for at least most of 1969. Refer to picture in post 4 in that thread.
https://67-72chevytrucks.com/vboard/...ht=1969+mirror
Jim |
#10 | |
I find mine's too flexable. It doesn't wobble at high speed, but everytime I put my mylar/bubble reflector shade in the windshield -- which is whenever it's parked in AZ -- the focus gets knocked around. There might be a way to tighten it up under the rubber cover -- I haven't messed with it.
OBTW, GM used the same mounting on all Rear View Mirrors from the early '60s thru MY 1971.
My '71 GMC Jimmy has a day/night mirror I cannibalized from a '64 Pontiac. The glue-on ones are fixed to a pivot ball.
