Old 07-03-2024, 06:07 PM   #1
RedBed
RedBed's Avatar
never ending leak - transmission
Where the transmission meets the driveshaft I have a leak that will not be fixed. Had the seal replaced twice. No luck.
And it doesn't leak constantly. It will be fine for a while, then I will come out one day and there will be a 16oz puddle under it.
I do not drive it often which makes it weirder.
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 07-03-2024, 06:24 PM   #2
Getter-Done
Getter-Done's Avatar
Re: never ending leak - transmission
The driveshaft yoke and rear bushing are probably worn cause your leak.
Is this a 4L60 transmission in your signature?
84 Chevy K-20
Old 07-03-2024, 07:09 PM   #3
RedBed
RedBed's Avatar
Originally Posted by Getter-Done View Post
...Is this a 4L60 transmission in your signature?
It is.
Old 07-03-2024, 10:35 PM   #4
400/400
Certainly sounds like a tail shaft bushing. Also check that the u-joints are in good shape.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 07-04-2024, 05:57 AM   #5
Dead Parrot
Not sure about the 4L60 but my TH350 had a similar problem. After replacing the tail shaft seal did nothing to fix the leak, further investigation revealed that there is an inner rear seal that also needs replacing. After having that replaced, no more leak.
Dead Parrot is offline   Reply With Quote
Old 07-06-2024, 10:18 AM   #6
Axle
Axle's Avatar
Had the tailshaft off the trans? Theres a cup and oring to help keep oil from getting out the tailshaft yoke vent hole. Mine is plugged with rtv to stop the drip.
Axle is offline   Reply With Quote
Old 07-06-2024, 05:32 PM   #7
RedBed
RedBed's Avatar
Thank you for all the replies!
