Old 07-24-2024, 09:13 AM   #1
Jim Boy
Needing help and has nothing to do with my age!
I posted in another forum but didn't get any response so I'm trying here.
Good day folks. I have a brain burner going on. The story.. 68 truck ran perfectly to the golf course. On the way home it started to backfire on acceleration. I thought it was mad at my score but it continued all the way home. So I thought that with the crappy fuel we have nowadays it must be in the carb. I had a kit so I rebuilt it. Fired up the money pit and it ran perfectly until it got hot and then the same problem occurred. I talked to a few knowledgeable guys and they said carburetor. So another kit and dider again. Same thing, no worky right. So there was two choices. Either beat the heck out of this money pit or be nice and spend some money on way overdo items. So I chose the latter and did a lot. It got new points and condenser, new coil I had in a box on the shelf, plugs and timing done. I even replaced the carb that c/w automatic choke for my old one from another engine that c/w manual choke, that engine ran perfectly. Same result.
So the 250 engine is idling for quite awhile while I'm standing there reading about the different needle movements on a vacuum gauge, when the engine just chugged a couple times and quit. We stared at each other for a while as I was not going to let it win. I figured that it ran out of gas from the carb. I took the top of the Rochester Monojet off and when I lifted it up the gas gurgled into the fuel bowl. Now, I'm a thinkin that I either have a stuck needle valve or my fuel pump is not doing the job after it has ran for a while. When cold, the engine will accelerate like it should but when it gets warm, bingo, bango, no ticky no worky.
That saying of "less is more" doesn't apply to old farts that like to talk(or type) as you probably have noticed. Just trying to eliminate questions. I will treat all replies with great interest and report as to whom is the winner.
Thanks in advance and have a good day eh!
Jim Boy is offline   Reply With Quote
Old 07-24-2024, 10:02 AM   #2
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
Re: Needing help and has nothing to do with my age!
I have found that backfiring is always a ignition problem. Have you checked your vacuum advance and timing.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 07-24-2024, 10:05 AM   #3
raggedjim
raggedjim's Avatar
Was the backfire through the carb or the mufflers? If through the carb I'd think timing issues, if through the mufflers I'm thinking unburnt fuel from either running rich or a cylinder not firing.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 07-24-2024, 10:17 AM   #4
68 P.O.S.
This ^^
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-24-2024, 10:40 AM   #5
LNP
If the fuel pump is not pumping efficently when cold the choke will be closed to richin the motor up but once its warm and the fuel supply is crappy its to lean and will run like crap backfire thru the carb etc. Do a couple simple fuel pump test. Check fuel pressure and fuel volume. Fuel volume simply hold a jar with the fuel line poking inside it have someone turn it over or start it up momentarily to see if it is pumping sufficently. Plus now you will have a fuel sample to look at to see if theres water or other crap in your fuel.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-24-2024, 10:51 AM   #6
loudchevy
loudchevy's Avatar
Similar to this suggestion, install a clear plastic fuel filter inline before the carb. I had a similar stalling issue years ago on my blazer, the clear filter would fill up when the truck was started and then slowly the filter had less and less fuel until it would die. Ended up being a cracked rubber fuel hose sucking air.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 07-25-2024, 08:43 PM   #7
mr48chev
mr48chev's Avatar
Original point and condenser ignition or ???
I need to be out checking the leads to the pickup coil in the HEI distributor on my 77 now as it is doing something very similar. I wouldn't put it past the hose between the fuel line and the fuel pump having a little air. leak though. I had the gasket between the manifold and head pipe leaking and blowing exhaust right on the fuel line causing vapor lock and may have cooked that hose and a hose is a lot easier to change than a distributor.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 07-25-2024, 11:26 PM   #8
davischevy
davischevy's Avatar
I had a similar problem. It was a Crack in the rotor.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 08-01-2024, 12:10 PM   #9
Jim Boy
Well fellow truckers the mystery is solved. I went around to all my contacts close by and the majority said the problem is the carb. So another kit but this time I followed the instructions as painful as it was and I now am in love again. Took her to the golf course today and she ran like a 56 year old should. In conclusion when I took the carb apart I found that the little hanging clip for the needle was broken. The clip was still on the needle part but the part that clips onto the float wasn't there. I'm guessing that I had a stuck needle. The jury is out on where the broken piece has departed too. I'm glad my wife isn't around to witness my stupidity as she would never let me live it down. That's why we men have caves. Thanks for your input, much appreciated. Thanks again.
PS> I now know why it takes ten years to build a hot rod::::FAMILY:::: You spend 25 years raising and educating your kids and then send them out into the real world. What do they do????Breed! They then return on mass and figure the rules are the same. They now know it all so you don't dare let them near your projects.
