07-27-2024, 01:40 PM | #1 |
Active Member
radiator frame Gasket?
Is there a gasket between the radiator shroud frame and the chassis frame on my 55.1 GMC-100?
After checking through a few books of mine I am not finding one and don't want to screw up any alignment issues with my hood / fenders?
1955.1 GMC 100 RestOMod 1972 T120RV 1967 C200 Trail 90 2014 TRD Quad CAB |
07-27-2024, 07:29 PM | #2 |
Re: radiator frame Gasket?
Classic parts shows a kit:
(1955-59) Radiator Support Mounting Kit Its just bolts and flat rubber washers. You could probably get the parts at a local hardware store and make your own.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
07-28-2024, 11:40 AM | #3 |
Active Member
Thank you nrdone!
I found what I needed on Ebay, and yes there are 2 pads required on a 47-55.1 between the radiator frame and the chassis frame.
07-28-2024, 12:02 PM | #4 |
The last time I had the front end off my 48 I think I used a section cut out of a two ply tire sidewall to make the rubber pads.
07-28-2024, 12:14 PM | #5 |
when I did mine I got rubber washers and bolts from Ace hardware. I think I spent less than $10.00. I also used nylock nuts to adjust in some free play
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! Last edited by nvrdone; 07-28-2024 at 12:42 PM. Reason: spelling |
07-29-2024, 01:41 AM | #6 |
47/early 49 have a U bolt in the middle and springs and a plate on the bottom of the springs.
07-29-2024, 02:28 AM | #7 |
They are the same square rubber pads that are used on the bed to frame mounts.
Some manuals have different thickness' to get the alignment of body panels to line up. Most I've read just add fender washers.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
08-02-2024, 10:57 AM | #8 |
OK, I got to ask the question...... I frequently see the typical use of the rubber pads with the coil springs & U-bolt configuration all the time. I am guessing your installing rubber pad(s) between the radiator core support & truck frame to insulate vibrations between the two components. What is the function of the coil springs & U-bolt?
Once you install all of the surrounding sheet metal inter-panels on the core support the radiator is locked into position & the springs nonfunctional. |
08-02-2024, 03:06 PM | #9 |
The U bolt was used on 47/48 trucks that had the center mount rear cab mount. I'm thinking that the idea was to be able to flex more without breaking anything when going over rough ground. That is something that we don't get real excited over now but back in 1947 they drove these trucks off across the field or pasture or up in the woods without a second thought.
