07-28-2024, 10:40 PM | #1 |
3/4 Ton Long to Short & Static Drop Square One
I just got this truck back on the road after shortening and dropping it, thought I'd post a few pictures of the build.
As I found it: Today short test drive:
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
07-28-2024, 10:44 PM | #2 |
Re: 3/4 Ton Long to Short & Static Drop Square One
A couple more before and after:
07-28-2024, 10:57 PM | #3 |
I call her Square One because as soon as I bought it I accidentally ended up with another that I call Square Two:
Square Two is actually a nicer truck but they are both great low mileage trucks with great patina and very little rust.
07-28-2024, 11:01 PM | #4 |
Square One (I believe) was some kind of work truck up in the Fraser Canyon, British Columbia, four or so hours north of Vancouver where I am now.
She's got the bumps and bruises of a yard truck but lots of obvious maintenance. Everything is greased up and running nice. Nicer now that I've cleaned the heck out of it and gone over everything.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" Last edited by kitsbeach; 07-29-2024 at 01:10 AM. |
07-28-2024, 11:06 PM | #5 |
Ripped the landscape bed off:
That was actually hard work. I was told the truck had a service truck bed on it but the guy threw it in the dump so that he could build this and landscape his yard. Gone now anyway...
07-28-2024, 11:22 PM | #6 |
The first thing I did was backdate the grille to the 73-74 style to get the vibe I wanted:
Before: Old grille off and orange marker lights added: This truck is a 1980 so there was a little change to where the 1973 lower grille bar attaches. I just cut the tabs of the lower grille bar and used some trim tape to install it (pic doesn't show it that well):
07-28-2024, 10:53 PM | #7 |
Junior Member
Looks great. What static drop did you use? I'd like a nice driver drop.
07-28-2024, 11:46 PM | #8 | |
It also has the 16" wheels so it sits a bit different than a 1/2 ton truck would. I kind of like it. Looks short and tough. The front is about a 1/2 inch higher than the back, which I'm also happy with but it may settle. The 3/4 ton springs up front are a bit bouncy, I may go to 1/2 ton front springs, but I think it would end up a bit lower. No rubbing at all, its very practical. Tires are 225/75R16 so pretty skinny
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" Last edited by kitsbeach; 09-18-2024 at 02:43 AM. |
07-28-2024, 11:51 PM | #9 |
Not many people drop and shorten a 3/4 ton but it had very little rust and great patina so I couldn't help myself I had to grab it.
I probably could have done a 1/2 ton conversion all round, but this is what I did.
07-29-2024, 12:15 AM | #10 |
Frame cuts
I did a bit of googling and talking to people this time about the frame cuts and fish plates (I've shortened my '67 too).
I like the thoughts shown in this picture: Also the idea of the fish plate welds going different directions than the stressors, like this example: So what I settled on this time was rounded ends on my fish plates so that the welds would be in different angles to the stressors, and also not to weld the plates continuously (used skip welds), so the plates actually have ability to flex. I got quite a bit of advice on this from pro welders.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" Last edited by kitsbeach; 07-29-2024 at 12:51 AM. |
07-29-2024, 12:22 AM | #11 |
Frame cuts and fish plates
BUT...I also knew that the chance of me getting the zigzag cuts perfect would be near impossible.
The zigzag cuts are the most popular on this site and all over the internet, but that means 6 different cuts ON EACH SIDE. Getting them to match up perfectly would be difficult. So I settled on nice big strong fishplates, with a good design, along with straight cut frame cuts. Basically wrong on the frame cuts and best on the fish plates.
07-29-2024, 06:38 PM | #12 | |
Junior Member
07-29-2024, 06:51 PM | #13 |
Following!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
07-29-2024, 07:36 PM | #14 |
Saginaw 3-speed swap
Some of these pictures are out of order but I swapped in a Saginaw 3-speed manual in place of the (I think) SM465 "bull low" 4-speed.
Adjusted Hurst shifter on the bench beforehand: Dropped this old hunk out myself, probably wasn't the wisest idea because it was heavy and almost killed me: Compared input shafts and I didn't need a new clutch disc (yay.!). Side to side comparison of length and shifter position:
07-30-2024, 08:44 AM | #15 |
Truck is looking good. Unfortunately that dent/wrinkle on the body line will be a doozy to make it look right.
Leaving this as a patina-ish build? |
07-30-2024, 10:25 AM | #16 |
Fix the front fender, and you'll have to fix the bed crease....fix the bed crease, and then the door ding will need attention, fix that and....
08-13-2024, 09:29 PM | #17 |
You know it.!
08-13-2024, 09:28 PM | #18 | |
The reason I couldn't help buying it was because it had great patina and no rust through. It has one cab mount that is in need of attention and I will do that. It came with no bed so the colour match and patina on the back is "faux".
08-19-2024, 01:33 AM | #19 |
frame paint
Ended up painting the frame as I went.
This started as a quick and dirty driver/patina build but the paint does make it look better even though it is not perfect.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" Last edited by kitsbeach; 08-19-2024 at 01:46 AM. |
08-19-2024, 01:46 AM | #20 |
bed floor cuts
Started cutting the bed floor. It needed 14" removed from the front but I decided to lap it and stitch weld it to save a whole lot of welding on bumpy dented bed floor, therefore I removed 12" or so.
I figured butt welding would be too time-consuming with all the waves in the bed floors, not to mention various dents and scars from the years. "Measure twice, cut once" is the saying and I almost cut too much out. I was scratching my head thinking about this but finally got going and it all worked out.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" Last edited by kitsbeach; 08-19-2024 at 01:51 AM. |
08-19-2024, 01:50 AM | #21 |
bed floor front welds
Here's some pictures of the bottom front of the bed and the stitch welds
Later on I will seam seal the whole thing
08-19-2024, 01:57 AM | #22 |
front bed support needed repair
The bed supports nearest the wheels were both rusty but I managed to save some money and used the deleted bed supports to get me what I needed.
The front just needed a patch piece.
08-19-2024, 02:00 AM | #23 |
bedfloor front
Here is a pic of the top before I welded it
08-20-2024, 07:17 AM | #24 |
Killer work man! Keep the motivation going.
08-20-2024, 07:47 AM | #25 |
Thanks man.! I'm probably forgetting about 100 important details but getting the main strokes posted here. If anyone has a question just ask I'll probably have a picture.
