Old 08-18-2024, 09:57 PM   #1
dmjlambert
dmjlambert's Avatar
Normal routing of headlight wires
Hi folks, what is the normal way the headlight wiring would have been routed for a 1963 C10? As you see right now it's probably just table lamp wire draped across the bumper brackets. And there is a ground wire coming out of a gap near the radiator and wrapping around the main negative battery cable and attached to engine. Looks funky to me and I'd like to straighten it out. The main charging cable between the horn relay and battery look pretty good, it's going through holes on both sides of the radiator support and going through clips under the top of the radiator support. I wonder if the headlight wires used to go along that path. What's the most proper way?
Old 08-19-2024, 01:57 AM   #2
Braunschweiger
Re: Normal routing of headlight wires
There should be plastic brackets in the grille to which the cable is attached, but they may be broken.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 08-19-2024, 07:27 AM   #3
bhap
bhap's Avatar
On my 62 the headlight wires ran from a plug in the driver side firewall along the inner fender to a grommet/plug in the driver side radiator support. It fed the left headlight and then the right. There were white plastic clips with small plugs that held the harness in place behind the grill. If you are cleaning up wiring, this would be a good opportunity to put in a couple of relays for your headlights.
bhap is offline   Reply With Quote
Old 08-19-2024, 05:29 PM   #4
ACK
ACK's Avatar
One of the best upgrades to my C10. Got a bunch of nice relays from the local pick'n'pull for next to nothing.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 08-19-2024, 08:04 PM   #5
dmjlambert
dmjlambert's Avatar
Great info here, thanks!
Old 08-19-2024, 09:59 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
The headlight relays are definitely the way to go. Made my T3 bulbs brighter and work really well with the Halogen sealed beams that I replaced the T3s with once one burned out
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-20-2024, 11:17 AM   #7
dmb
Active Member
dmb's Avatar
This is what I used, plug and play
https://www.ebay.com/itm/124148130601
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 08-20-2024, 01:45 PM   #8
dmb
Active Member
dmb's Avatar
I used this kit was very pleased
headlight wiring
