08-19-2024, 01:02 PM | #1 |
Which Accelerator Pedal?
The cab on my 70 C10 does not have holes for the ball studs for the accelerator pedal. This leads me to believe it is a late 70's cab. I currently have the linkage for a pedal that mounts to the floor.
Would I be better installing the ball studs or switching to the 71 accelerator assembly? The engine has a Sniper EFI and a TH 400 transmission with a Lockar kickdown switch. Thanks |
08-19-2024, 02:08 PM | #2 |
Re: Which Accelerator Pedal?
By far the later floating pedal unless you are looking or something that looks original.
08-19-2024, 08:32 PM | #3 |
I just installed a application where a bell crank was used for throttle. Connecting to the 1972 pedal was so simple it was almost disappointing. No thought or effort needed.
08-19-2024, 08:48 PM | #4 |
There is a hybrid approach that I plan to use, 71/72 style floating pedal on earlier throttle setup. https://67-72chevytrucks.com/vboard/...40#post7871640
08-20-2024, 12:59 PM | #5 |
The 1971/72 cable system was far superior over the 1967-70 rod system.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
08-20-2024, 01:18 PM | #6 |
Not ideal , but I took the pedal off my '69 many years ago . Seems to work fine without it .
08-20-2024, 04:26 PM | #7 |
I've got a 67 with the floor mounted pedal.
I've had all the parts to convert it to the later style " floating" type. I think they look better and thought I'd like to have it. I started down the road to the conversion but ran into a hiccup . That was about 15 years ago and I rarely even give it a thought when I'm driving the old girl. Maybe when I retire.
I got a bench seat baby, you don't have to sit over there. |
08-20-2024, 04:50 PM | #8 |
I'm really leaning to the 71 set up. I'm not sure on the hybrid set up yet, fab work seems to bite me in the butt more often than not.
Looked at Lokar for a complete set up- nice but pricey......... I'm going to keep looking. Thanks |
08-21-2024, 07:53 PM | #9 |
I changed out the accelerator/throttle set up in my '68 C/10 Stepside. I used a 71/72 Gas Pedal and armature. Had to move the action outboard by an inch or so. Used a cable throttle. Much better Throttle response, and no jams or failures.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-21-2024 at 08:12 PM. |
08-22-2024, 10:36 AM | #10 |
Any suggestions on the best kit to buy that is as complete as possible?
Looking at Lokar- but I don't like the price. I want this project to be as simple as possible. Thanks |
08-22-2024, 02:09 PM | #11 |
I went with this brand I got from my local Hot Rod Shop:
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-22-2024 at 02:39 PM. |
08-22-2024, 04:45 PM | #12 |
I want to do this swap as well. The floor mounted go pedal reminds me of a racing arcade game from the 90's.
The lokar kit does look nice but like you mention is pricey and it doesn't include the cable.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
08-22-2024, 05:17 PM | #13 |
68OrangeSunshine- what brand was that?
Thanks |
08-22-2024, 09:49 PM | #14 |
Sorry, Buddy,
I've searched my Pictures in my Laptop. I ran thru the Gallery on my mobilephone and it's not there. Must've got wiped. It's in the Glovebox of the Orange truck, but I'm out of town and won't be home until the end of the month. I'll look then. As I recall the company was in Santa Rosa or Santa Clara CA.
08-22-2024, 11:16 PM | #15 |
08-23-2024, 04:01 PM | #16 |
Switch to the 71/72 cable type. If the left side motor mount breaks, which isn’t that uncommon, the throttle could stick on you and cause an accident. It’s easy and can be done with factory parts, with the exception of an adapter plate, which can be made or bought. Search cable throttle conversion and you should get a few threads to come up for reference.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
