Old 09-07-2024, 07:29 AM   #1
Chevy nutcase
Chevy nutcase's Avatar
66 exhaust routing
Just recently finished a motor and tranny swap along with extensive cab floor repair on my c10 and as always there's more to be done. I ran the exhaust with Thrush glasspacks and while they were suitable in my teen years I want it quieter now. Right now they dump in front of the rear tires and I'd really like the new setup with turbo mufflers to exit straight out back. Problem is with this being lowered about 3", on the driver side the panhard bar is in the way. I was wondering if the mount for the bar on the frame could be modified to raise or lower it two inches to give me a clear shot. Making a new mount is no problem but I don't know if there's some geometry I'm overlooking as to why this may or may not be a good idea. If this can't be done I'll have to cross over the diff and take the pipes to the outside of the frame.
Umm editor if you could please give me a flip thx
Chevy nutcase is offline   Reply With Quote
Old 09-07-2024, 11:21 AM   #2
dmjlambert
dmjlambert's Avatar
Re: 66 exhaust routing
How is the spacing from front to back? Enough to bring the exhaust pipe straight down between the axle and panhard bar? I can't tell from your picture looking straight at the back if the bar sticks out far enough from the axle like mine does.
Just lowering should not affect how the exhaust routes because it would have been routed to avoid the axle or panhard bar from hitting the exhaust when driving over a large bump with stock suspension when the axle can move all the way up to the rubber bumper on the frame.
If you must, it should be harmless to re-work the panhard bar in some way because all it does is keep the axle from moving side to side.
Old 09-07-2024, 05:56 PM   #3
Chevy nutcase
With my truck being lowered I envy stock height or lifted trucks. I probably have 1 ½ between the bar and duff and 2" between the bar and the crossmember. Not enough to sneak 2 ½ out. If nobody tried making a new mount I might be the guinea pig. The mount is easily removed with 3 rivets and if my plan goes south I can always put it back
Old 09-07-2024, 01:37 PM   #4
AcampoDave
AcampoDave's Avatar
I went outside the frame. It worked well because my gas tank is right there in the middle anyhow.
Perhaps the side exit may still be fine if you had a quieter muffler though. I just sold a truck having before the tire exits. I'm not into exhaust noise at all so i had added resonators to each pipe. It was nice and quiet with that arrangement.
AcampoDave is offline   Reply With Quote
Old 09-07-2024, 07:33 PM   #5
dmjlambert
dmjlambert's Avatar
Just route the exhaust over the axle on the passenger side where there's plenty of room. Your panhard bar doesn't go all the way across the truck like mine does. If dual exhaust, just run both pipes next to each other until after the differential and panhard bar.
Old 09-07-2024, 08:30 PM   #6
Chevy nutcase
I considered doing that and its 6 in one half dozen in the other but im leaning towards lowering the mount to allow two straight runs out. Doing exhaust is a pain enough but I enjoy the thought of a custom mount. If the mount doesn't work for whatever reason I might take them both out on the passenger side.
Old 09-08-2024, 02:11 AM   #7
Agv63
I have a 455 pontiac in my 63, 2.5" pipes and going outside of the frame, one straight thru big size glass packed muffler, and dumps about 6" before the rear wheels, it is actually not loud, good sound just sounds a bit wonky as i must still add a crossover tube.
Could run it the same and add more mufflers or just extend pipes on outside of frame. Depending your wheel size it should fit. Will add some pics i took from internet.. not my truck but neatly done.
Cheers.
Adriaan.
Agv63 is offline   Reply With Quote
Old 09-08-2024, 07:37 AM   #8
WorldsCrappiestTruck
Active Member
With a rear tank, lowered and wanting a rear-exit, it was a challenge. Add to that wanting a relatively quiet truck.
I have an LS, Speed Engineering headers, to 8” Flowmaster universal cats, then a 2.5” stainless system from there. The pipes were a kit, and elbows/45’s etc from Amazon that I cut & welded sections together to route accordingly. The mufflers were Jones Exhaust from summit which I LOVE. They are super quiet at idle, have a nice tone going down the road with zero drone, but blatt loudly at WOT.
Fabbing all this up was a challenge but I’m very pleased with the result.
WorldsCrappiestTruck is offline   Reply With Quote
Old 09-08-2024, 10:35 AM   #9
rbruno68
That is a great job on running that exhaust. I took the easy way out and dumped in front of the axle.
Rob
rbruno68 is offline   Reply With Quote
Old 01-12-2025, 12:34 PM   #10
txinliner
txinliner's Avatar
i went in front of front kick up and on the outside of the rail with it dumping in front of rear tire, one of the best things is nothing is seen under the truck
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 01-14-2025, 01:04 PM   #11
SCOTI
SCOTI's Avatar
Go w/an aftermarket 'long' Panhard bar (https://nolimit.net/store/No-Limit-L...-Rod-p26244500).
It mounts lower on the chassis & rear end for a better impact on chassis dynamics (Lower Roll Center that's adjustable) while improving its effectiveness vs GM's OE short bar.
Another benefit is additional exhaust clearance vs the stock bars location/placement. *disclaimer* It could also possibly create clearance issues though depending on how the exhaust is done/routed.
Rotated your image:
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
