![]() Join Date: Jul 2000
Ideas for spare tire location
Over the years I used the OE under-bed carrier, and later just put the spare in the bed under a vinyl cover. Both the wheel and tire were old and nasty looking, so they were never stolen.
Now I have a nicer wheel and newer tire, so I'm looking for options to secure them in the bed. I have the under-bed carrier parts, but would hate to remove the spare while lying on my back next to a busy highway or in the rain. Show me what you guys and gals have been using for bed mounts.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Who Changed This?
![]() Join Date: Jan 2013
Re: Ideas for spare tire location
I bought an in-bed tire carrier from LMC. I have the carrier under the truck, but like you, I'm disinclined to lay under the truck or even hunch down to get the spare out of there. Especially if I was towing the travel trailer. I've since sold that trailer and bought a motorhome, as mentioned in another thread. AAA is going to change a flat on that thing.
https://www.lmctruck.com/body-compon...tire-carrier-9
![]() Join Date: Jul 2001
I use an original GM in-bed spare tire bracket bought years ago at a salvage yard. Had originally intended the under bed spare thing til a friend mentioned about the thrill he had one time of crawling under the truck in the mud and rain to gain access for spare to change a flat. Gave up that under bed thought real quick, mounted the spare left side up close to the D/S corner. Not in the way when turning to look thru the back glass. Seen later he had done the same spare tire mount.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#4 | |
Just dug out my so-called "nicer" wheel and newer tire, and neither one is either of those! So, no loss if I don't use them, and maybe I can sell the 15x8 rally wheel at a swap meet or on Facebook Marketplace.
Who Changed This?
You'd just need a longer stud, but that's probably the most expensive part of the kit. I checked my spare. It is a 215/85R on a 16" Suburban wheel. There's about 1-1/2" of extra thread on the stud. It appears to be the same outside diameter as the 9.50-16.5 Transforce tires I have on the ground. I've never used the spare, so I don't even know if the tires on the ground can fit on that mount. Wish I had thought of that. If it doesn't fit later, I'll just weld on an extension to the stud.
#6 | |
![]() ![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I've thought about using a crank up type underbed carrier from a Toyota for example.
![]() Join Date: Jun 2022
Thinking the same thing. Cobble together a collar to use the same crank as the jack
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
Who Changed This?
Astrovans have a setup like that as well.
#10 | |
I'm not a big fan of the stock tire carrier. You could whip up something like I did on the cheap. I've got $20.00 something bucks invested in this. The winch came off a Mitsubishi truck. Some scrap metal, little welding, some bolts & nuts, and no more cussing the stock set-up! I set it up so the crank rod is on the passenger side of the truck. Painted the crank rod yellow so I can find it in the tool box. The safety cable was for peace of mind. |
![]() ![]() Join Date: Jul 2002
I was going to swap my factory underbed carrier to crank down one from a 92 C1500, Then I went and put a squarebody suburban gas tank in that location. I got an in-bed mount from LMC. IT is simple and works well and was pretty cheap. about the same as folks were trying to sell used factory ones. I mounted mine on the passenger side rear, because of where the filler neck is for the fuel tank.
20' Daredevil (Ret)
![]() Join Date: May 2003
^^^^ That's a great idea. I might try to rig up something like that if I ever have to rassle with my spare again.
A few years when ago I finally replaced my original (!) spare with something newer, I think I taught myself a few new words.....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Sep 2014
I remember this post from LockDoc many years back.
It’s at post #14. https://www.67-72chevytrucks.com/vbo...d.php?t=578124 I had a photo of a red C10 long bed at the NW Goodguys several years back but I must have deleted it. Same set up as above on a long bed pickup with the inverted wheel tub into the right rear floor bed. It was well done and functional.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
I really like that. No tire sticking up above the bed side. But it would be a no-go for me, since my truck's paint is new and the bed is Rhino lined.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-24-2024 at 12:15 PM. |
#15 |
Who Changed This?
I have a BBC, so dual exhaust. It wouldn't work for me, either, but it's pretty cool!
