09-24-2024, 05:16 PM | #1 |
Anyone have a low mount AC Comp on an LS
I have a 71 K20 that is getting a truck 6.0. I will be adding an aftermarket air system from one of the various companies. I'm looking for an ac compressor that will fit in the factory location on the engine. The factory one will fit, but there is no way the lines can attach to the compressor without hitting the frame. I have trimmed the frame some, but I'm not willing to go far enough for the lines to clear. I would really like it mounted low since I've already cleared the frame.
Is there such thing? It looks like the dirty dingo low mount could possibly work with the Sanden they sell. The lines come out farther up. Does anyone have pics if they have mounted low? |
09-24-2024, 05:55 PM | #2 |
Re: Anyone have a low mount AC Comp on an LS
I know I've seen low mount pumps on these trucks at the shows. Sanden makes pump heads with various outlet configurations and lines can be had that come directly off the head low profile and wrap around the pump to come out elsewhere. https://coldhose.com/collections/san...mpressor-heads https://www.carid.com/holley/a-c-com...199-201bk.html EDIT: Have a look at this thread. The picture posted (link) shows a sanden low on an LS. The head they used shoots the lines off that way. Another head could shoot them off another way. https://67-72chevytrucks.com/vboard/...d.php?t=768432 Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 09-24-2024 at 06:07 PM. |
09-24-2024, 06:21 PM | #3 |
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
09-25-2024, 06:29 AM | #4 |
Thanks guys,
The end caps for the compressor looks promising, for sure. |
09-25-2024, 08:19 AM | #5 |
Holley (Alan Grove) bracket with Sanden compressor
Down low and out of sight on my '67 with LS1 factory compressor would not fit
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-25-2024, 10:01 AM | #6 | |
09-25-2024, 10:52 AM | #7 |
Here's one
I bought a short hard line and bent it for the suction side, the high pressure side uses a 90º crimp on fitting on reduced barrier hose to go to the condensor. The high pressure port is under the battery tray, just barely enough to connect to. I also put the heater valve close by, you can barely see it under the hoses. It's a close fit but I like how it's hidden away. let me know if you want more pictures.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 09-25-2024 at 11:06 AM. |
09-25-2024, 02:37 PM | #8 |
https://ls1tech.com/forums/conversio...71-c-10-a.html
Here's an example of a stock compressor with reworked lines.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
09-25-2024, 07:20 PM | #9 |
Awesome guys, thank you! I'll try to document what I end up with.
09-25-2024, 11:21 PM | #10 |
I have a 68 with a 4.8 in stock v8 location , stock 03 ls compressor , clears. AC not hooked up yet , but a company called cold hose sells pn AA2209-AA2210 , LS fittings that put both lines straight out the front , looks like it will clear with no notching. If anyone has tried these I'd like to know , hopefully this winter is the winter I do the ac...
09-26-2024, 06:49 AM | #11 | |
09-26-2024, 07:05 AM | #12 |
09-27-2024, 08:00 AM | #13 |
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
09-27-2024, 08:37 AM | #14 | |
Thanks! |
09-29-2024, 06:32 PM | #15 |
I used the Dirty Dingo low mount bracket set up and a Sanden style A/C compressor. I used this A/C line adapter with 45 degree fittings and cleared the factory curved lip. It does get a little funky with the water pump/heater core lines right above this, did the best I could with that situation.
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
