11-01-2024, 07:57 AM | #1 |
Electronic ignition
It's been a long time since I played down this road. Some terminology may not be correct.
Vehicle has a 327, seems to be factory electronic ignition. I seem to have no spark at the plugs. Cap, rotor, look ok. Removed coil cover. Checked wires, seem to be good here too. Removed coil. Removed black washer/insulator. Removed spring but a part was left in the dizzy.... Looks like it's broke.... Would this be my issue? If yes, what is the name of this part? Thanks much...Don. |
11-01-2024, 02:09 PM | #2 |
Re: Electronic ignition
Thats the carbon button that connects the center tower in the cap to the rotor. It's usually positively retained in the cap - not sure it can be replaced outside of replacing the cap...?
11-01-2024, 05:15 PM | #3 |
Replace the cap. Great pics btw.
11-02-2024, 06:41 AM | #4 |
That part being broken is consistent with your no spark symptom.
11-02-2024, 07:10 AM | #5 |
Thank you all.
Very much appreciated...Don. |
11-02-2024, 01:56 PM | #6 |
Is this factory electronic ignition actually a transistorized ignition? Or just an hei.
It might be worth a chunk of change! You got pics of it? Last edited by geezer#99; 11-02-2024 at 02:28 PM. |
11-03-2024, 08:25 AM | #7 |
IIRC it's a GM HEI. This is the best pic I got....
FWIW....Im not a mechanic outside of shade tree maintenance. This issue is in the wife's toy.... She likes it...Don. |
11-03-2024, 08:52 AM | #8 |
Yup, just an hei!
11-03-2024, 06:20 PM | #9 |
Don't see too many of those - nice!
Make sure the HEI is getting a full 12V as well. |
11-06-2024, 08:55 AM | #10 |
11-06-2024, 10:41 AM | #11 |
11-28-2024, 08:36 AM | #12 |
Update. Friend who knows more about electronics than I.
HEI wire is powered in fuse box the ign unfused stud. I get 11.74 volts at the stud. Batt = 12.4v. Got 11.74v power to the HEI coil. Got no power to the ignition module. R&R module. She runs like a scalded dog. Thanks all....Don. |
11-30-2024, 01:33 PM | #13 |
Thanks for the update, good deal!!
