11-01-2024, 01:02 PM | #1 |
1969 396 engine completely rebuilt
I live in Cooperstown NY. Asking 6250. (Lowered to 5950. on Nov. 30. 2024) for the engine. I have the receipt for this exact amount to rebuild it.
This 396 engine was in my 1969 GMC 2500 Longhorn truck and I had it totally rebuilt but it has never been installed. I decided to not finish the restoration of this truck so the engine alone is now for sale. If you are planning to put this into a 67-72 GM truck I have all sorts of parts that bolts onto this engine: complete PS brackets pump and hoses, engine mounts, engine stands, new alternator etc. Here is what was done by a professional rebuild by Alan Steere: - Degreased - Decks squared to main - Lifters bored out and enlarged to .875 - Bored and honed, .030 over square to the main - Block was deck-plated when honed and bored - Re-surfaced cylinder heads (Original heads) .010 - Connecting rods magnafluxed and resized with new bolts - Crankshaft 10 + 10 (uses oversize bearings). - Balanced rotating assembly - New SS valves, 3 angle valve job - New pistons, rods and main bearings - New cam, lifters, pushrods, rocker arms, timing chain and gears, oil pump and screen. All blueprinted. - Cam specs: @.050 duration 210 degrees on intake, 215 degrees on exhaust, , valve lifters .440 on both, and 114 degrees separation angle. - New valve spring locks and retainers - Heads milled .010 - File fit the rings - New fly wheel and flex plate - New harmonic balancer - Pre-lubed and then run for 30 minutes on engine stand (Video avaliable) - Then changed the oil again. NOTE: I am not an engine guy. I just paid to have all this done to this original 1969 396 engine. Original heads used. But if you need to know the brand of certain parts you will have to talk to the guy who built the engine. Alan Steere of Schuyler Lake NY. Alan has been building GM engines for racing use as well as everyday use for decades and there were no shortcuts on this engine. Video now available. Text me your phone number and I can send you a video of it running. The video is one minute long.
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. Last edited by georgieb51; 11-30-2024 at 09:35 PM. |
11-03-2024, 11:38 AM | #2 |
Re: 1969 396 engine completely rebuilt
Someone out there needs this engine! Better than new.
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
11-30-2024, 09:33 PM | #3 |
Someone out there is thinking of putting a big bock into their small block truck. Buy this engine and it includes all the parts to make that happen. And please feel free to make an offer. Price is lower than what is cost to have the work done.
12-03-2024, 12:12 PM | #4 |
HOw low should I go? Or do people just no longer want an original 396? I wish I had a truck to put it in. A nice clean one that only needed an engine swap.
12-03-2024, 12:15 PM | #5 |
How low do you think I should go/ Does anyone even want a 396 anymore? Or have LS swaps replaced them?
12-05-2024, 03:13 PM | #6 |
Curious what is the date and engine code?
12-05-2024, 03:33 PM | #7 |
csting number is 3955272. Stamping on engine block pad is T0227 YQ which refers to a 396 installed in a 1969 C20 and the build date was February 27 (0227). I may have a photo of the casting date on the block but the photos I have are quite illegible bt I will post a few. And I am not really sure if they are the correct casting that you need.
12-10-2024, 11:11 PM | #8 |
I have a late ‘68, looking for an XG code. Thank you
12-11-2024, 12:42 AM | #9 |
I am not sure what you mean by an XG code.
12-12-2024, 11:10 PM | #10 |
12-13-2024, 09:47 AM | #11 |
I understand now. MIght take a while to find that I wonder how many 68 C10 trucks had a 396 installed?
12-13-2024, 11:28 AM | #12 | |
There was a young guy on here, been a while. Asking questions about a big block (68-72, not sure which) that he had. He wasn't getting too many responses. He was getting impatient. Someone her, or maybe me explained that 396/402 engines were not very common, at all, in these pickups. He did not like that response, he thought that, FOR SURE, there were as many big blocks as there were small blocks manufactured....... |
12-11-2024, 06:52 AM | #13 |
One of the First
Wish you were closer. If you ever get down to Florida, LMK.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
12-11-2024, 12:25 PM | #14 |
I have never been to Florida.What are you planning to build?
12-12-2024, 09:36 PM | #15 |
One of the First
My 70 C-30 would love the upgrade. Running a Standard SBC in it now.
12-13-2024, 01:03 PM | #16 |
It might be possible for me to deliver the engine. That is if I can fit it into my Subaru Outback. .
12-14-2024, 11:35 AM | #17 |
One of the First
Interested - Freight would be the way to go, just more $$.
12-14-2024, 09:29 PM | #18 |
It could be shipped. I think it weights around 700 pounds. It woiuld require a very sturday palette. and while I can pick it up with an engine crane or a chainhoist in the shop, it would be tough to get it onto a delivery sort of truck. Myabe you would know more about these things?
12-16-2024, 11:13 AM | #19 |
Don't mean to get in the middle of your conversation, but I just had a small block engine shipped from PA to GA through Fastenal for $207. The other guy got it to a Fastenal store near him on a pallet, then I picked up at my local store here in GA.
12-16-2024, 11:57 AM | #20 |
Chevy Freak
I was the " other " guy in this case lol. Worked out good!
Nick 71 K20 5.9 p pump cummins (in progress) 68 Camaro 454BBC 86 Camaro 5.3LS turbo |
12-16-2024, 12:18 PM | #21 |
Thank you for your comments. I have used Fastenal in the past for a tailgate. They did a good job and that seems to be a reasonable price for shipping your engine. I could probably do that if someone was serious. It would definitely require a sturdy palette.
12-17-2024, 08:34 AM | #22 |
One of the First
Defiantly an idea, I've never used Fastenal for shipping. Very interested, wished I could pursue this, but with Christmas at hand I can't do anything at the moment. If this still available after the holidays, let's try and work something out. I will PM you with my phone number for the video.
12-17-2024, 10:34 AM | #23 | |
12-17-2024, 11:05 AM | #24 |
One of the First
Got your message and video - sweet sounding big block. Ill try and reach out this afternoon or tomorrow. Thanks
